Shocks
Old Oct 3, 2024 | 02:20 AM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
Guys, I just bought a 03 anniversary corvette and I am going to be changing the shocks. I’ve read that Bilstein is the way to go (I know that you have to reprogram) I have a bunch different ones that I’ve seen mentioned, I know that it should be the HD and not the sport ones, what I don’t know is B6, monotone, 46mm. I’ve seen shocks for this car that could cause me to take a second mortgage out. Suggestions please? Geez this wasn’t as complicated as shocks for my 65 fuelie (which I sold about 20 years ago) I know I should have kept it.
Old Oct 3, 2024 | 05:23 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
The Bilstein shocks are are great product; they are reasonably priced and available from multiple outlets. I've used them on two C5s; I had a set of B6s (HD shocks) on an 01 coupe I had years ago, and I'm running a set of B8s (sport shocks) on my current 02 Z06.
Old Oct 4, 2024 | 05:53 PM
PetrofMII's Avatar
PetrofMII
I replaced the leaking shocks on my 2003 AE with the Bilstein B6 (HD) shocks and love them. This is my DD and long road trip car, so the HDs were the appropriate choice for my use case.
Old Oct 5, 2024 | 12:57 AM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
Thanks, I think I’m going with the b6 HD, That would be the 4600 correct? Also what did you do with the electric, resistor ? Or delete or do you have to do both?
Old Oct 5, 2024 | 05:49 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
My cars did not have the selective ride control. The Bilstein 4600 is a coil over shock, are you planning on removing the transverse leaf springs? Bad idea in my opinion.
Old Oct 5, 2024 | 06:29 AM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
Oh no, stock. Just want a set of Bilstein b6 hd but there seems to be a few different ones, sorry I don’t have a part number
Old Oct 5, 2024 | 07:10 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Rockauto sells both the B6 & B8 for C5 Corvettes.
Old Oct 5, 2024 | 07:20 AM
PetrofMII's Avatar
PetrofMII
You must have the program for the magnetic ride shocks "tuned out". Find a Corvette shop that can do this for you.
Old Oct 5, 2024 | 09:41 AM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
Thanks ipuig, went to Rock and the ones I saw are saying without electronic suspension,b6 performance, stock ride height, part number 24029759. Would this be them even though it is with electronic suspension and are these HD?
Old Oct 5, 2024 | 01:28 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
I'm not comfortable in telling you which shock to order but you must realize that a non selective ride suspension shock is not the replacement part for your vehicle. As I indicated, my cars did not have the selective ride suspension, so the Bilstein shocks are considered a direct replacement for the OEM shocks. Many on this forum claim to have replaced their magnetic ride shocks with standard shocks, I do not have direct knowledge of this part swap so I'm reluctant to give an opinion on it. Good luck.
Old Oct 5, 2024 | 01:35 PM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
I'm not comfortable in telling you which shock to order but you must realize that a non selective ride suspension shock is not the replacement part for your vehicle. As I indicated, my cars did not have the selective ride suspension, so the Bilstein shocks are considered a direct replacement for the OEM shocks. Good luck.
Ok I understand that, Original replacements are very expensive.
Maybe someone else here who has or had the selective ride could chime in with some advice
Old Oct 5, 2024 | 01:38 PM
PetrofMII's Avatar
PetrofMII
Let's start this from the beginning. All the 2003 AE cars were equipped with RPO F55 "Chassis Continuously Variable Real Time Damping Magneto Rheological" (or simply magnetic ride) shocks. To replace these with ANYTHING other than the OEM mag ride shocks, you MUST have the F55 program deleted from your car's computer. Someone with a TECH II, HP Tuner or equivalent MUST delete the program. Then you can replace the OEM shocks with Bilsteins or some other solution.
Old Oct 6, 2024 | 12:08 AM
Yankee Jim's Avatar
Yankee Jim
PetrofMII You might have the answers for me.
there looks like there’s a few BilsteinB6s that fit the 03 ae . Would you know the part number or the exact shock that you used and what did you do to the magnetic deal ? Thanks very much
Old Oct 6, 2024 | 10:41 AM
PetrofMII's Avatar
PetrofMII
If you have the car at the normal height, there is only one set of B6 shocks that fit. Front is 24-029759, rear is 24-029766. Before these can be installed, you must have the F55 program deleted. I took my AE roadster to a Corvette specialist shop here in DFW and they deleted the mag ride shock program from my car's computer. I personally do not own a TECH II and don't feel the need (yet) to invest in and learn the HP Tuner system, so I rely on experts to handle issues such as this,
Again, the program must be deleted before you change out the shocks.
Old Oct 6, 2024 | 11:28 AM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
Ok thanks, I’m in n Dallas also.In Lavon near Wylie.
Who did you bring it to delete? Thanks
Jim
Old Oct 6, 2024 | 06:39 PM
PetrofMII's Avatar
PetrofMII
21st Century Muscle Cars on Midway. Started by the daughter of Lingenfelter.
Old Oct 6, 2024 | 08:27 PM
Yankee Jim's Avatar
Yankee Jim
Default Shocks
Thanks, I just spoke to the guy that is selling it to me, he said a friend of his has a scanner which I forgot that name of ( I think it was called two letters and a number or two numbers and a letter. I don’t remember, but he said he could probably take care of it for me. Anyway I found the shocks on ama for $450 front and rears, Appreciate your help.Oh maybe od2 scanner.If he can’t do it I’ll contact Midway.
Jim
Old Oct 7, 2024 | 07:33 AM
PetrofMII's Avatar
PetrofMII
Cool. Enjoy that beautiful vehicle!
To Shocks
