Is this column lock?
Old Oct 3, 2024 | 08:36 PM
Slow99frc's Avatar
Slow99frc
Default Is this column lock?
My 99 manual transmission frc is cranking over then dying. Sometimes it will run for a second sometimes die literally the second it cranks. I have no codes but in my dash I have the “remove key for 10 sec” prompt. I had a shop look at it, I had maf and ckp codes but they fixed those. They found a bent maf pin and fixed it then the car ran. I drove it two days in a row… now its doing it again. Is this column lock? I have no idea atp. Tia
Old Oct 3, 2024 | 09:14 PM
mmartinez's Avatar
mmartinez
Column lock problems usually manifest as a 2 mph fuel shut off, the car will start but the moment it moves forward it will turn off.
Old Oct 3, 2024 | 09:15 PM
Slow99frc's Avatar
Slow99frc
So not that, could it be the battery or alternator?
Old Oct 4, 2024 | 12:19 AM
mmartinez's Avatar
mmartinez
Not battery or alternator related, I belive it's still related to the maf, or fuel related problem, and since you don't have codes it's not a seriel data buss problem. Might think about taking back to the shop.
Old Oct 4, 2024 | 07:33 AM
lucky131969's Avatar
lucky131969
Originally Posted by Slow99frc
I have no codes but in my dash ...
What does this mean? You used a code reader at the DLC? You actually tried to pull codes from the DIC?
Old Oct 4, 2024 | 12:03 PM
Slow99frc's Avatar
Slow99frc
I used a code reader because my dic doesn’t work
Old Oct 4, 2024 | 12:20 PM
lucky131969
Sounds like it is not capable of reading BCM DTCs. When you get a "pull key and wait 10 sec" message, and pull key and turn ignition back to on, that should generate a "service column lock" message on the DIC and set a DTC.
Old Oct 4, 2024 | 12:21 PM
Slow99frc's Avatar
Slow99frc
I do not get s service column lock message
Old Oct 4, 2024 | 12:24 PM
lucky131969
Do you know if your car has an LMC5 module or equivalent ?
http://complianceparts.com/lmc5ataglance.html
Old Oct 4, 2024 | 12:26 PM
Slow99frc's Avatar
Slow99frc
I believe it has the recall. I can turn the wheel with the key out
Old Oct 4, 2024 | 12:30 PM
lucky131969
It's important to know if the harness is at the BCM.
Old Oct 4, 2024 | 12:31 PM
Slow99frc's Avatar
Slow99frc
I will go look. It under the passenger footwell right?
Old Oct 4, 2024 | 01:47 PM
lucky131969
Yes.
Old Oct 4, 2024 | 01:48 PM
lucky131969
https://www.corvetteforum.com/forums...ky-please.html
Old Oct 4, 2024 | 01:50 PM
Slow99frc's Avatar
Slow99frc
so im looking for it and it doesn’t seem to have it. What I did notice is the car seems to crank over for slightly longer after moving my steering wheel whether thats turning it or changing the position on the column
Old Oct 4, 2024 | 01:52 PM
lucky131969
Please use the link provided for more details.
Old Oct 4, 2024 | 01:58 PM
Slow99frc's Avatar
Slow99frc
yeah I have the recall but it does say it could be faulty. Another thought, could it be my clutch switch?
To Is this column lock?
Old Oct 4, 2024 | 02:03 PM
lucky131969
It the engine cranks there is nothing wrong with the clutch switch.
Old Oct 4, 2024 | 02:12 PM
Slow99frc's Avatar
Slow99frc
okay. Yeah idk this is a hard one. It doesn’t make sense that it cranks up enough for me to rev after moving my steering column a bunch. Maybe something is grounding out?
Old Oct 4, 2024 | 02:17 PM
lucky131969
I think you are chasing a ghost there.....I would focus on the data you have.
