service traction sys, shocks inoperative, reduced engine power codes
Old Oct 19, 2024 | 10:04 AM
flappybird's Avatar
flappybird
4th Gear
Default service traction sys, shocks inoperative, reduced engine power codes
I purchased my first 99 corvette about 2 months ago, and yesterday I drove it around 150 miles to Kalamazoo, MI with a friend, everything is fine. But the next morning, I see the following codes:
service traction system
shocks inoperative
check tire pressure
reduced engine power (when this shows, the radio turns off)
But the "reduced engine power" goes away after some minutes, then comes back, then goes away...
Then all the codes goes away in the afternoon and during the night, everything seems fine again. Then the next morning, same codes appeared.
So I think is it because I'm in Michigan, it's cold and moist in the morning and I probably have some electric problem? Any help is much appreciated!
Old Oct 19, 2024 | 03:51 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you have a scan tool let us know what trouble codes you may have…if not you can use the DIC which has a “built in” code reader…video below how to accomplish this.
Old Oct 19, 2024 | 08:50 PM
Lowend's Avatar
Lowend
Did you happen to install LED bulbs on the car? Believe it or not the low resistance can screw with the ECM and cause stuff like this. Good news is $10 of resistors can fix it
Old Oct 19, 2024 | 09:47 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Have your battery load tested. A low battery will cause all kinds of weird messages.
Old Oct 20, 2024 | 01:59 PM
flappybird's Avatar
flappybird
4th Gear
Thanks for the suggestion, I'll get the battery checked once I got time
Old Oct 20, 2024 | 02:01 PM
flappybird's Avatar
flappybird
4th Gear
No, all lights are stock
Old Oct 20, 2024 | 10:36 PM
Lowend's Avatar
Lowend
Ok - good chance the is a ground issue - well known problems with the C5
Start here
https://www.corvetteforum.com/forums...tion-long.html
To service traction sys, shocks inoperative, reduced engine power codes
