Mystery transmission squeel
when its in gear and i raise the clutch pedal from the floor it starts to make a dry rubbing sound. As soon as i push the clutch pedal back down the noise stops. Any info on anyone who has experienced this will be greatly appreciated. Iam currently under the assumption that i have a bad pilot bearing.
P.S i guess i will. Start taking it apart and change all components to the clutch system. Cultch is shot. JMO
