SVO Injector install NIGHTMARE
Ok, this may be painfully obvious but SVO's are not Plug and Play on a stock motor.. Your PCM went ballistic trying to pull back on all that extra fuel. I am guessing you exceeded the -25LTFT limit..
Did you set any codes?
You really need to use a MAFT or reprogram the PCM to handle that big of a change.
You definatly need to check your DIC codes, and/or do an OBD-II diagnostic, to see where you trims are at.
Every engine reacts a little different to mods.
[Modified by kewlbrz, 12:09 AM 2/6/2003]
Your car does not need bigger injectors.
I should add that I doubt you will be able to tune this with your standard Predator tune. You need to tune your closed loop metering and I do not think you can do that with an out of the box Predator. You would need a custom Predator tune or better yet a change to the Injector Flow Rate with LS1Edit. Best bet is to just run the stock injectors. Your duty cycle should not be too bad with the stockers and your current mods.
However, I find the statement is somewhat misleading. It really depends on what your trying to do.
This mod was extremely popular before the days of LS1Edit. It allowed for manipulating fuel trims into the negative region in conjuction with a MAFT. Which made WOT tuning a lot better, and helped add some timing by changing perceived engine loads.
Many still use larger than necessary injectors even with LS1Edit for broader tuning options, when not necessarily needed for specific HP requirements.
GM has played with injector sizing throughout the history of the C5 for various tuning and performance reasons, but also followed it up with programming changes to compliment the change.
With that said, unless one knows what they are doing, I recommend against fooling with injectors.
But there is bennefit beyond a simple HP need.
[Modified by kewlbrz, 10:08 AM 2/6/2003]
FWIW, adding WOT high-load/High-RPM timing to a stock 02-03 Z06 is going to result in a gain of about 0 HP and additional knock signals. Not sure about an LS1 since I've yet to test one of those.
