04 No Map Light or Underhood Light
Old Oct 24, 2024 | 07:28 PM
btwilson's Avatar
btwilson
Default 04 No Map Light or Underhood Light
I have an 04 C5 kinda baffled if anyone could point in the right direction. Mirror lights work as should footwear and cargo lights all good. But no vanity underhood or glove box light.Hmmm. I pulled fuse 2 last night and checked looked ok. Bulb in underhood light looks new. Any thoughts would be appreciated.
Old Oct 24, 2024 | 07:52 PM
capeokw56's Avatar
capeokw56
With the hood open look for a wire that hangs down at the front of the hood on the passenger side. It has a connector about 18 inches down. Check to see if it is connected. Lots of owners disconnect it so that the light stays off when working under the hood. That way it doesn't kill the battery.
Old Oct 24, 2024 | 08:05 PM
btwilson's Avatar
btwilson
It was unhooked and I plugged in still nothing.
Old Oct 24, 2024 | 09:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you know how to read a wiring diagram ??…do you have a 12 volt test light and know how to check a relay with it ??…looking at a fuse doesn’t mean you have power going to it…I’d look at Relay 37 in the IP Fusebox….you could swap out the relay and see if all 3 of those lights work…you could also jumper the load side of the relay and also see if the lights work…it could also be the control side of the relay not energizing the load side…that would be the Monitored LD Relay control circuit from the BCM.
Old Oct 24, 2024 | 09:55 PM
btwilson's Avatar
btwilson
I do have a test light I think I will try a new relay and see if that works. If no go there chase further. Thanks for your insight really appreciated it. Brian
Old Oct 25, 2024 | 07:17 PM
btwilson's Avatar
btwilson
I tried a new no 37 relay tonight unfortunately didn't get anything. Do you know if the interior lights are all running to the same ground? I am not the best at reading schematics. Would love to see it its a bad group. Thanks Brian
Old Oct 25, 2024 | 07:36 PM
C5 Diag's Avatar
C5 Diag
There are 2 separate grounds for all 3 of those lights so that’s not it…if you have a test light see if the test light illuminates on each test point of fuse 2…test light should illuminate on both test points on top of the fuse…beyond this I don’t know if you want to check the relay…2 of the relay terminals should light when testing as you can see is “hot at all times”…beyond this I don’t know how much more of this circuit you want to test or bring the car to an auto electric shop…worst case you have a bad BCM…unfortunately not all electrical issues are a blown fuse…one needs to have some basic electrical knowledge.
Old Oct 25, 2024 | 07:50 PM
btwilson's Avatar
btwilson
OK I will check that with test light. Will probably try and find a good electric shop if that's even possible in this enlightened age LOL thanks again for your help.
Old Oct 25, 2024 | 08:59 PM
btwilson's Avatar
btwilson
If it is a bad BCM is there a good place to purchase that you are aware of?
Old Oct 25, 2024 | 09:12 PM
C5 Diag's Avatar
C5 Diag
You can try a salvage yard or eBay if you want to go that route…try Google too and BTW it’s not plug and play…it will have to be programmed.
Old Oct 25, 2024 | 09:33 PM
btwilson's Avatar
btwilson
understood hopefully a local shop can programme if need be. My local Chevrolet dealer has gotten nuts on there shop charges.
Old Oct 25, 2024 | 09:36 PM
C5 Diag's Avatar
C5 Diag
Just call around…a local repair shop may be able to do it…it can also be a broken wire so don’t think it has to be the BCM.
Old Oct 25, 2024 | 09:54 PM
btwilson's Avatar
btwilson
I understand sounds like you sure no your way around Corvettes.
To 04 No Map Light or Underhood Light
