P1518 error code on 2003 after battery change?
Old Oct 27, 2024 | 12:12 PM
spartan6056's Avatar
spartan6056
Default P1518 error code on 2003 after battery change?
So I recently swapped the battery in my car since it died (not surprising considering the battery was really old). I put the new one in, and I got the check engine light on startup. The code showed P1518, which upon searching says it's an issue with the throttle actuator control module. I got the code cleared, and it hasn't come back after driving for about 20 minutes, but I know that's not much time. I haven't had any of the symptoms associated with the error code. Everything drives completely normal as far as I can tell. I even got on it a little and didn't feel an issues with performance. Is this something I should be concerned about, or is it just a glitch from swapping the battery?
Old Oct 27, 2024 | 03:48 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Don’t know if you checked your new battery before starting the car but I’ve seen new batteries that have been sitting on the shelf for a while have low voltage…just see if that DTC returns.
Old Oct 27, 2024 | 04:04 PM
spartan6056
I did check the new battery before installing it, and it was good. Although I didn't know that about the DTC P1518 code. When my battery died, I was getting the low voltage warning, and it wouldn't crank. Maybe that code carried over from when it had the old battery?
Old Oct 27, 2024 | 04:48 PM
C5 Diag's Avatar
C5 Diag
Well let us know if the DTC comes back…unfortunately it’s not something like a blown fuse.
Old Jan 12, 2026 | 01:41 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by hen step
I can help you with the electrical issues
This thread is 1 1/2 years old...OP probably has it figured out by now.
To P1518 error code on 2003 after battery change?
