Fuel Tank Replacement Instructions
Old Nov 15, 2024 | 10:34 AM
jviar734's Avatar
jviar734
Cruising
Default Fuel Tank Replacement Instructions
I am new to Corvette and to this forum. Just bought a 2004 Z06 that has the crossover tube connection fuel leak. I need to source new tanks and would like a step-by-step written or video for doing it. Have read a lot of forums about the issue, just having problems finding how to's and where to buy new or mildly used tanks. Thanks for the help.
Old Nov 15, 2024 | 10:51 AM
lucky131969's Avatar
lucky131969
All I can offer is the factory service manual.
Old Nov 15, 2024 | 10:57 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
03.5/04 Corvette is much the same:
https://www.corvetteforum.com/forums...fuel-pump.html
Be very careful with the plastic clips retaining the lines inside the crossover tube.
Old Nov 15, 2024 | 11:01 AM
jviar734's Avatar
jviar734
Cruising
Exactly what I was looking for. Thanks.
Old Nov 15, 2024 | 11:02 AM
jviar734's Avatar
jviar734
Cruising
Thanks Lucky131969. I have ordered the CD with the service manual and should get it soon. Wasn't sure if they have a play by play in it but will search it as well.
Old Nov 15, 2024 | 11:27 AM
lucky131969
Most service manuals are written with the assumption that the person doing the maintenance has some knowledge of the platform......and an aptitude to do the work. So you will not find a "play-by-play" (hand-holding so-to-speak). The value the service manual provides that the typical youtube mechanic does not capture are specific warnings, correct tools required, fastener specs, order of operations, etc.
Old Nov 15, 2024 | 11:35 AM
jviar734's Avatar
jviar734
Cruising
Appreciate the heads up. I am new to corvette but have been autocrossing a 1998 BMW 328ic for years so not new to working on cars 😊. Specific tools needed I will figure out. It looks like the crossover tube is the hardest part so thanks for the extra words of caution. The link 93polo sent was perfect and just was I was looking for. Now i just have to find the tanks and time to do the work. Again, thanks for the heads up and information.
Old Nov 15, 2024 | 02:40 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Googling C6 Corvette fuel pump replacement will turn up more on here and youtube.
Old Nov 24, 2024 | 02:53 PM
jviar734's Avatar
jviar734
Cruising
Default Project done now new problem
Appreciate all the information before. Switched out the driver side fuel tank with a 2006 tank that had 19,000 miles on it. Came with fuel pump. Started the car and fuel gauge was on empty. We had put at least 8 gallons in the tank. Low gauge warning light came on. Went and filled it up with 8 gallons. Tank went up to half a tank only. Trying to figure out what happened. Any help or pointing in the right direction to another thread would be very helpful. Car runs great
Old Nov 24, 2024 | 03:28 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://www.corvetteforum.com/forums...-e85-pump.html
Old Nov 24, 2024 | 03:40 PM
lucky131969
I'm assuming you did not test the sender before install? If that's the case, you could have a bad sending unit. Double check all your connections between the two tanks....the fuel sending units share a low reference connection.
Old Nov 24, 2024 | 05:09 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Symptoms are consistent with being the later fuel level sensor after GM changed the voltages. You maybe able to change a table with HP Tuners, or swap back to the early sensor
For anyone on any C5/6 much of the fuel system stuff is getting expensive so never throw away old lines, solenoids etc if they are in working condition.
Old Nov 24, 2024 | 05:21 PM
jviar734's Avatar
jviar734
Cruising
Look like I may have a sending unit that needs retuned. Will look into how to get this done. Appreciate the help.
Old Nov 24, 2024 | 08:30 PM
don37's Avatar
don37
Veteran: Canadian Forces
do you reside in WA?
Old Nov 25, 2024 | 05:56 AM
jviar734's Avatar
jviar734
Cruising
I am on the east coast.
Old Nov 27, 2024 | 10:47 PM
Alley Oop's Avatar
Alley Oop
Excellent video on removing fuel tanks on a C6 which is virtually the same as a C5.
Fuel Sending Unit C6 Corvette
Old Dec 9, 2024 | 06:03 AM
jviar734's Avatar
jviar734
Cruising
so now I have a new problem. I’ve been looking for somebody close by to reflash the ECU to pick up the new sending unit from the 07 unit I put in. Now the fuel gauge reads empty the whole time. Here’s what I’m thinking. I need to drop the tank and get a new fuel pump and sending unit formy year, 2004, and just put it in and be done with it. any suggestions?
To Fuel Tank Replacement Instructions
Old Dec 9, 2024 | 06:26 AM
don37's Avatar
don37
why would it read empty the entire time? I would think the guage would at least operate in reverse....
Old Dec 9, 2024 | 06:27 AM
don37's Avatar
don37
url supposed to be in your post?
Old Dec 14, 2024 | 04:32 PM
jviar734's Avatar
jviar734
Cruising
Still not sure what to do so asking again. To recap, I bought a 2004 z06 and had to replace the DS tank due to the well known crossover tube to tank issue. Bought a 2007 tank with 19000 miles on it and put it in (had the 2007 fuel pump in it so did not change it. Fuel gauge read 1/2 full when the tank was full. Figured it was the sending unit polarity change that I read about in the forum (evidently GM reversed the polarity on this unit in 2007). Was looking for a tuner to adjust the ECU to accept this but still have not found one locally. In the mean time, the fuel gauge now reads empty all the time and the display center is stuck on low fuel gauge and none of the buttons work to the right of the steering wheel. Car runs great. Any ideas? I think I’m going to have to pull the tank again and put in a new fuel pump for my year (unless one of you knows what’s going on and can help my ignorance).
