Hose Identification help
Old Nov 29, 2024 | 02:15 PM
99FRC Newb's Avatar
99FRC Newb
Default Hose Identification help
Hi everyone!
I found this tucked under my battery tray. Is it supposed to connect to something?
Old Nov 29, 2024 | 02:22 PM
lucky131969's Avatar
lucky131969
You have to find the other end to know for sure. Have you checked for vacuum when the engine is running? Is your A.I.R. system still working/functional? Are all your vacuum related accessories working normally?
Old Nov 29, 2024 | 02:41 PM
99FRC Newb's Avatar
99FRC Newb
Ah, that makes sense. The A.I.R. system has been deleted.
Old Oct 29, 2025 | 08:31 AM
99FRC Newb's Avatar
99FRC Newb
Found the other end. It goes to the back of the intake manifold.
Old Oct 29, 2025 | 08:46 AM
lucky131969
That would imply that the original rigid tube failed at some point, and someone installed rubber hose.....but the other end is plugged, so that would cause issues with your HVAC...air coming from all vents, etc.
...and you never answered the questions from 1 year ago....
Old Nov 2, 2025 | 01:53 PM
99FRC Newb's Avatar
99FRC Newb
AIR system is gone. HVAC didn’t work when the car was together.
What other vacuum related accessories were you referring to?
Old Nov 2, 2025 | 06:16 PM
lucky131969
You never stated that the HVAC was not working.
Old Nov 2, 2025 | 09:37 PM
99FRC Newb's Avatar
99FRC Newb
I know. That’s why I just added it then asked if there was anything else vacuum-related. I wasn’t being passive aggressive. I just worded it poorly. Sorry.
To Hose Identification help
