Radiator hose blew off
Old Dec 12, 2024 | 05:03 PM
Espi2's Avatar
Espi2
Default Radiator hose blew off
Had a fun afternoon on the way back from the shop. Radiator hose on the drive side blew off completely and quickly lost all coolant so pulled over. Reattached the hose and filled her back up with coolant but looks like it is running a little hotter than normal at idle - right around 215ish.
I've done some reading and it looks like when something like this happens, air can get in the radiator/coolant lines which may cause it to run hotter. Anything I can do to remedy this? Also, no idea how the hose came off - the radiator hasn't been touched for several years.
Lastly - looks like some faint smoke burning off near the radiator - assuming its excess coolant that spewed everywhere. Should I expect that until I clean it up?
Old Dec 12, 2024 | 05:15 PM
Eleven Bravo's Avatar
Eleven Bravo
Did your car overheat when it blew the hose? Are your fans coming on? They're on a fuse. There are some easy to follow instructions on getting air out of you cooling system. You'll probably want to do that.
Old Dec 12, 2024 | 05:21 PM
lucky131969's Avatar
lucky131969
https://www.corvetteforum.com/forums...nt-system.html
A very unusual situation. What failed? Did the hose spit? Is the radiator cracked? Did it still have the factory spring clamp?
Old Dec 12, 2024 | 05:37 PM
Espi2's Avatar
Espi2
this forum is awesome - thanks for the link.
nothing actually failed from what I can tell, looks like the clamp/hose popped off somehiw. Looks to be factory clamp, probably getting a new one just in case.
Old Dec 12, 2024 | 05:52 PM
Espi2's Avatar
Espi2
definitely pegged the temp gauge so pretty sure it was overheating but i caught it pretty quickly I think once I realized what happened.
Old Dec 12, 2024 | 05:54 PM
lucky131969
I would do a pressure test before servicing and air bleed.
Old Dec 12, 2024 | 05:55 PM
Espi2's Avatar
Espi2
excuse the ignorance but what is a pressure test?
Old Dec 12, 2024 | 06:13 PM
Dads2kconvertible's Avatar
Dads2kconvertible
It's when you add pressure to your cooling system. The idea being find and fix any leaks before wasting some coolant and the time it takes to bleed the air out of the system.
Old Dec 12, 2024 | 06:16 PM
Espi2's Avatar
Espi2
got it - thanks. Seems odd there would be a leak, wondering if there is some odd buildup of pressure that caused the hose to blow off on just a shitty clamp.
Old Dec 12, 2024 | 06:20 PM
lucky131969
https://www.corvetteforum.com/forums...ow-to-vid.html
Old Dec 12, 2024 | 06:22 PM
lucky131969
Does it? Nothing is more odd than a hose coming off all on it's own. You are testing for weakness, not just for leaks.
Old Dec 12, 2024 | 06:24 PM
Espi2's Avatar
Espi2
ok - got it. Will do the testing then. Definitely want to avoid this.
Old Dec 13, 2024 | 09:19 AM
grinder11's Avatar
grinder11
It could've been, and could currently still be, a bad thermostat. How old is your Tstat? Was your coolant at the proper level? I have had a factory spring clamp lose tension, but only slightly leak. So I replaced them all with conventional hose clamps. Never had a hose blow completely off. That is an extreme situation. I fear you have overheated the engine for whatever reason, and only noticed the high coolant temps after the hose blew off. I hope I am wrong. Just get a new hose, and possibly (I would definitely!) a new Tstat, unless you just recently replaced it. BTW, Amazon is great for some things, but its not a great place to buy internal engine parts, among other things. I only buy C5 stuff from them if they're the only place I can find what I need.....
Old Dec 13, 2024 | 01:28 PM
Espi2's Avatar
Espi2
It could've been, and could currently still be, a bad thermostat. How old is your Tstat? Was your coolant at the proper level? I have had a factory spring clamp lose tension, but only slightly leak. So I replaced them all with conventional hose clamps. Never had a hose blow completely off. That is an extreme situation. I fear you have overheated the engine for whatever reason, and only noticed the high coolant temps after the hose blew off. I hope I am wrong. Just get a new hose, and possibly (I would definitely!) a new Tstat, unless you just recently replaced it. BTW, Amazon is great for some things, but it’not a great place to buy internal engine parts, among other things. I only buy C5 stuff from them if they're the only place I can find what I need.....
yea, definitely concerned here. Made the 10 hour trip from fl to nc without issue and then this within a quick 30 min drive. New hoses/clamps and thermostat ordered and on the way.
Espi2's Avatar
Espi2
no milky residue on oil cap, dipstick looks good and the engine and exhaust aren’t smoking. Hopefully I avoided major isssues.
Old Dec 13, 2024 | 01:44 PM
lucky131969
Ok, if you responded immedately, the chances of damage are slim to none. A stock LS1 is designed to run with no coolant for 50 miles.
Old Dec 13, 2024 | 02:08 PM
Espi2's Avatar
Espi2
good to know. Only drove for maybe 2 mins before pulling over and shutting it down once I noticed the coolant flying everywhere. Initially thought someone in front hit a massive puddle but then realized it wasn’t raining 😀
To Radiator hose blew off
Old Dec 13, 2024 | 02:20 PM
Eleven Bravo
Did you verify your cooling fans are operating as they should?
Old Dec 13, 2024 | 02:24 PM
Espi2's Avatar
Espi2
not yet but I will.
Old Dec 13, 2024 | 04:16 PM
Espi2's Avatar
Espi2
ran through the process to remove the air in the coolant reservoir/radiator. Car would stay around 220 once warmed and after running through the 3k rpm intervals. Turned on the heat and cooled it down to around 195. There is too much coolant so I need to drain a bunch but will do that once the thermostat comes in. Not sure if that would cause it to run hotter.
