Lamp Actuator
Old Dec 14, 2024 | 02:20 PM
JKendall's Avatar
JKendall
2nd Gear
Default Lamp Actuator
Replacing the lamp actuator on my C5. The one I’m replacing has two holes (unthreaded) that slide onto the bolts and then you tighten the nuts on them. My new one came with the holes threaded. I can’t slide it onto the bolts. Anyone ever had an issue with this and how did you put the new one on?
Old Dec 14, 2024 | 09:44 PM
jcgunn's Avatar
jcgunn
Okay, what is a "lamp actuator?" Are you asking about the headlight assembly?
Old Dec 14, 2024 | 11:27 PM
Moved to C5 Tech.
Old Dec 15, 2024 | 10:10 AM
lucky131969's Avatar
lucky131969
If you are going to jump on a forum for the first time, it helps to provide minimum info:
-Model year
-Exactly what you are doing, and events leading up to you asking for help
Pics also help. Did you get the actuator off amazon or ebay motors?
Old Dec 15, 2024 | 10:12 AM
lucky131969
Loosely referred to has the lightlight motor, the actual task for replacing in the service manual is " Headlamp Motor/Actuator Replacement" It's also referred to as an actuator in the GM parts manual.
To Lamp Actuator
