Welding
Old Feb 8, 2003 | 04:24 PM
Cousteau's Avatar
Cousteau
Default Welding
I have discovered bad welds where the exhaust pipes are welded to the flanges on the left and right pipes at the rear on either side of the transmission. I would like to weld up the cracks. Is there any electronics issues related to welding the pipes while on the car? I donot want to fry any electronics with the welding machine.
Old Feb 8, 2003 | 04:26 PM
twincam47's Avatar
twincam47
Default Re: Welding (Cousteau)
disconnect the battery!
Old Feb 8, 2003 | 08:48 PM
Miles in Michigan's Avatar
Miles in Michigan
I think you can have the GM dealer do it for free. A TSB came out on this issue.
Unfortunately I had mine welded at an exhaust shop, before the TSB came out, so it cost me $70.
Old Feb 8, 2003 | 08:59 PM
Dave00C5's Avatar
Dave00C5
Default Re: Welding (Miles in Michigan)
:iagree: Let GM do the welding. :cheers:
Old Feb 8, 2003 | 09:34 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Welding (Dave00C5)
If you do decide to weld it on your own, make sure you disconnect the battery!
To Welding
