How Do you pick a CAM???
I originally ordered a Comp Cam 228228/ .588/.588 112 lsa.. agressive.
The time lag on the order and listening more to input from others and reading more signatures, I backed down to the TR 224/224 .563/.563 112 lsa thinking agressive but not far out! Now I'm thinking why aren't I getting the reverse split by TR 230/224 .575/.563 111 LSA Would this be agressive but also street friendly? Now ..once I finally take delivery of a CAM I guess I can stop re-thinking and wondering what if? Take me out and shoot me! :confused:
Look at some of the posts here of people who paid good money for mismatched cam and heads, dyno'd low rwhp, then had to have someone else redo it.
1 - Pass smog
2 - Idle not too rough
3 - Not too cruel to the valves.... Longevity... I am keeping the car for MANY years
4 - More HP
Been thinking about the LS6 cam, but getting a lot of flak :)
Any suggestions?
- C5B
I understand the theory of reverse split, at least much of it. Since the intake close dictates much of the power a cam makes, to extend it out with a wider intake allows to have less overlap and make power across a broader rpm range. Less overlap will maintain low/mid range torque while the later closing of the intake lobe offers high end power. nice. however, the RS cam you mention still has a lot of overlap at 111lsa, even more with the wider intake lobe.
If you have a set of heads that have been ported to where the exhaust flows are about 85-87% of intake, a straight-up cam will work great.
Phillip
