4.10 install questions
Old Feb 8, 2003 | 11:43 PM
boost2much's Avatar
boost2much
Default 4.10 install questions
I'm going to install my 4.10s and was reading the service manual and have a few questions. Do you need the special leaf compressor tool? Do I have to remove the tranny or could I just remove the differential without taking out the tranny? Are there any parts besides gear oil I should get before starting the install? Anything else I should be aware of? THANKS :seeya
Old Feb 8, 2003 | 11:48 PM
davidfarmer's Avatar
davidfarmer
Default Re: 4.10 install questions (boost2much)
You don't have to remove the spring. You drop the entire rear suspension with the subframe. You should not need any special tools, but I hope you have a "lift".
Dave
Old Feb 8, 2003 | 11:51 PM
boost2much's Avatar
boost2much
Default Re: 4.10 install questions (davidfarmer)
Yes, I have access to a lift. Good to know that I don't have to get that special tool the manual says.
Old Feb 9, 2003 | 12:18 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Its much easier with a trans jack as well.. dont forget the limited slip additive. :seeya
Old Feb 9, 2003 | 02:53 AM
kwik8racr's Avatar
kwik8racr
Default Re: 4.10 install questions (CHRIS NJ C5)
No need to remove the tranny, it will drop down far enough to remove the diff. from the back of the tranny, no special tools needed, I am sure a trans jack is nice, but I do mine all the time with just a floor jack. :cheers:
Old Feb 9, 2003 | 10:49 AM
Cruise-In V Veteran
Default Re: 4.10 install questions (kwik8racr)
I was mentioning a trans jack to take down the rear cradle, not the tranmission. :seeya :seeya :seeya
Old Feb 9, 2003 | 11:32 AM
kwik8racr's Avatar
kwik8racr
Thats what I was refering to also, I just use a floor jack with a block of wood on top to drop the cradle :)
Old Feb 10, 2003 | 12:43 AM
boost2much's Avatar
boost2much
I will be doing the install at a performance shop so have the tranny jack, lift, etc... Do I need the addiditive for the differential? I am going to use Redline and heard that it already had it in. I currently have Redline in my 3.42 and have no problems. :steering:
To 4.10 install questions
