Alternator Question
Old Jan 4, 2025 | 09:39 PM
USN32's Avatar
USN32
Default Alternator Question
I was going to replace my alternator with an ACDELCO OEM 110 amps as part of my idler pulley, tensioner, etc. replacements when I noticed that I currently have a 230 amps alternator. I’ve only had the car 3 months and to the best of my knowledge it’s stock with the exception of a K&N CAI, magna flow catback exhaust, and an ATI harmonic balancer. That being said, it seems like everytime I start a new project I find something else that I wasn’t expecting.
Any idea why someone would put this on and if there are any issues I will induce by transitioning back to the stock alternator? Would the wiring be different than stock with this setup?
Old Jan 4, 2025 | 09:59 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Unless you have a 50,000 watt sound system no need for a 230 amp alternator…110 is fine !!
Old Jan 4, 2025 | 10:04 PM
C5 Diag's Avatar
C5 Diag
This is the stock alternator pin out…if yours is like this you’re fine.
Old Jan 4, 2025 | 10:07 PM
USN32's Avatar
USN32
Thanks! I’ll check it out.
Old Jan 4, 2025 | 10:25 PM
Dads2kconvertible's Avatar
Dads2kconvertible
You should read the alternator sticky. The C5 is picky about alternators.
Old Jan 5, 2025 | 10:13 AM
Fast one's Avatar
Fast one
Is the alternator not charging right or giving error codes? If not why do you want to replace it?
To Alternator Question
