Hvac issues blend door
Old Jan 19, 2025 | 05:07 PM
lucky131969's Avatar
lucky131969
Originally Posted by Woopigsooie00
I replaced the line from the passenger fender to underneath the passenger side where it connects to the purple and vacuum is back to 40 plus but still did not fix the problem
the DIC did end up giving me two codes though B0361 HC B0441 H
Why did you replace the line? Did you find a break? 40 plus?......sticking with the cm Hg scale? Are you using a hand pump, or just running the engine this whole time?
Old Jan 19, 2025 | 06:09 PM
Woopigsooie00's Avatar
Woopigsooie00
found a crack in the ine at firewall.
16 in/hg at start up
using the engine, no hand pump.
Old Jan 19, 2025 | 06:11 PM
lucky131969
Ok...obviously that is low
Old Jan 19, 2025 | 07:31 PM
Woopigsooie00
Where could it be leaking from? Vacuum Canister?
Goes from the vacuum source at fender 20.4 in/hg to 16in/hg.
Old Jan 19, 2025 | 11:26 PM
lucky131969
Yes, which is why you need a hand pump to isolate.
Old Jan 20, 2025 | 12:28 PM
Woopigsooie00
ordered a new hand pump should be here today
Old Jan 20, 2025 | 06:52 PM
lucky131969
Always good to have an assortment of vacuum tubing connectors and caps too.....makes troubleshooting a breeze.
