MAF screen removal
Old Feb 9, 2003 | 06:59 PM
Resqjoc's Avatar
Resqjoc
Default MAF screen removal
I know this question has been asked before, but I can not find any reference to this question.
Can anyone explain to me, the best way to remove the screens on a stock MAF for a 99 Coupe???
Old Feb 9, 2003 | 07:31 PM
MTWallet's Avatar
MTWallet
Default Re: MAF screen removal (Resqjoc)
Take off the MAF and insert a needle nose pliers into the screen and twist. This will cause it to break away from the inside of the housing and come out. It destroys the screen, but it comes right out. I have never seen one removed in one piece.
Old Feb 9, 2003 | 07:41 PM
Resqjoc's Avatar
Resqjoc
Default Re: MAF screen removal (MTWallet)
Thanks, I will try that. Are adding those air foil items to the MAF have any benefit???
Old Feb 10, 2003 | 10:55 AM
carpe dm's Avatar
carpe dm
Make sure you really want to do this, as it is irreversable. Why not buy an after-market MAF housing to see if your car will run the way you want, or to see if there is any benefit, without destroying your MAF? I think you will find there is VERY little effect, and possible problems involved. :rolleyes:
Old Feb 10, 2003 | 10:34 PM
Lynn2008's Avatar
Lynn2008
Default Re: MAF screen removal (carpe dm)
I was going to do remove mine this week. What kind of problems are you speaking of?
Old Feb 10, 2003 | 11:23 PM
1g1yy's Avatar
1g1yy
Default Re: MAF screen removal (ericg320)
I removed my screens a couple of months ago -- absolutely no problems. At the same time I installed a Vortech cold air system, Haltech CF air bridge with coupler, Hypertech programmer, Bassani X-pipe and Borla Stingers, so I can't say whether removing the screens added any power. I can tell you though that overall now my car feels a bit more responsive -- it moves out right smartly! :yesnod: :lol:
Old Feb 11, 2003 | 12:11 AM
MTWallet's Avatar
MTWallet
This is not destroying the MAF. All you are doing is removing the screen. GM did this in 2002 and on the Z06, so it can't be a bad thing. No, you can't replace it, but it doesn't hurt it. I never had a single code or anything pop up. I did notice a little better throttle response but who knows.
[Modified by MTWallet, 7:05 PM 2/11/2003]
Old Feb 11, 2003 | 01:03 AM
hogurt's Avatar
hogurt
Removed mine. . .no problemo :D
If it's not on the Z, why is it on me?
Old Feb 11, 2003 | 09:57 AM
Hokie's Avatar
Hokie
Default Re: MAF screen removal (hogurt)
I removed mine with no problems. Just be very careful so you don't hit the little wires.
Old Feb 11, 2003 | 10:11 AM
Mike TexaSS's Avatar
Mike TexaSS
Default Re: MAF screen removal (Hokie)
I removed mine way back in may of 02. And autotapped the car before and after. I saw more timing and more grams per second of air than before a good mod IMHO. I also have this done to my 96 impala ss.
Old Feb 11, 2003 | 10:20 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
I removed ours last September and installed a Blackwing at the same time. No problems at all.
Old Feb 11, 2003 | 10:43 AM
Fast one's Avatar
Fast one
Default Re: MAF screen removal (Mark 84ltblu)
I marked the side then took the assembly apart first so the sensors wouldn't be damaged; the screen can then be knocked out with a hammer handle and the opening smoothed.
Old Feb 11, 2003 | 10:53 AM
IMQUIK's Avatar
IMQUIK
Took mine out...NO problems!! :thumbs:
Old Feb 11, 2003 | 12:48 PM
ndirishr1's Avatar
ndirishr1
I removed mine on my 01 vert. Did it same time as adding a Vortex unit. No problems noted.
Old Feb 11, 2003 | 01:03 PM
Allgonoshow's Avatar
Allgonoshow
Default Re: MAF screen removal (ndirishr1)
Took mine out a year ago and NO PROBLEMS WHATSOEVER!!!!! on my all stock ride(besides the spray).
Old Feb 11, 2003 | 06:11 PM
aaaa's Avatar
aaaa
Default Re: MAF screen removal (Allgonoshow)
took mine out of my 2000. M y 2002 doesn't have a screen. Makes me feel good about removing it from the 2000. Maybe GM is listening to us?
Old Feb 11, 2003 | 08:44 PM
billiam01's Avatar
billiam01
I used a razor knife to work it out after removing the MAF; it took some time but I feel I could re-install it if I wanted to. I had no problems and for added insurance use the computer re-learn process. :chevy
To MAF screen removal
Old Feb 11, 2003 | 10:15 PM
Resqjoc's Avatar
Resqjoc
Default Re: MAF screen removal (billiam01)
If I remove the screens, should I put new MAF ends on also?? I know this is not necessary, but will it make a difference??
Old Feb 11, 2003 | 10:47 PM
kewlbrz's Avatar
kewlbrz
The only reason the C5 has the screens, is because the MAF is shared with the truck line. The trucks MAFs are positioned in a way that the air flow is very turbulent, and the screen is used to help with laminar airflow. John Juriga, GM Powertrain chief, said it wasnt needed for the C5, and since there was nothing negative about not having it in a C5, they took the screen out for the needed improvment of airflow for the 405 Z06.
I cut mine out a long time ago on my 01. And ran screenless maf ends when I had my 2000. No issues whatsoever for 1000's of miles on both. The peak HP increase is going to be extremely small on stock motors, but all the little things add up! :cheers:
[Modified by kewlbrz, 10:42 PM 2/11/2003]
Old Feb 11, 2003 | 11:06 PM
jimman's Avatar
jimman
Default Re: MAF screen removal (kewlbrz)
:iagree:
