Bad C5 Harmonic Balancer?
Old Jan 28, 2025 | 10:05 PM
colbyJc5's Avatar
colbyJc5
4th Gear
Default Bad C5 Harmonic Balancer?
I’ve been getting this high pitch whistling sound almost with a little bit of bird chirping sounds too. Checked it out and maybe see a little wobble in the harmonic balancer. Does this need to be replaced?
https://m.youtube.com/shorts/e8OBVftN3hA
Old Jan 28, 2025 | 11:41 PM
Ltngdrvr's Avatar
Ltngdrvr
Video file doesn't work for me, maybe put it on youtube then link it here.
But, the balancer would not make a whistling sound or chirping, maybe a bad idler pulley.
Also, how old is the belt?
Old Jan 29, 2025 | 12:22 AM
bookyoh's Avatar
bookyoh
The simplest recommendation when this question is asked:
1. Take a white paint pen or something similar and paint a white mark from the inner steel to the outer steel of the balancer. Watch the white mark over the next days or week and see if the pulley portion moves relative to the inner portion.
2. Remove the serpentine belt and see if the noise goes away.
3. If the noise went away, replace the belt.
Old Jan 29, 2025 | 12:43 AM
colbyJc5's Avatar
colbyJc5
4th Gear
Belt is almost new, same with the tensioner , let me fix the file real quick
Old Jan 29, 2025 | 07:50 AM
Ltngdrvr's Avatar
Ltngdrvr
Well, I am not seeing or hearing anything that would bother me were it my car.
Balancer looks to be running true, and the sounds are nothing alarming to me.
Old Jan 29, 2025 | 07:59 AM
Andybump's Avatar
Andybump
I had the bad balancer problem with my C5 at around 85000 miles. It sounds exactly like a squealing belt. I don't recall that it had noticeable wobble. Before I knew what it was,, I thought it was the belt. At first it was intermittent, then it got worse. If it is that, it needs to be replaced before it fully separates and causes major damage.
I want to add - the reason it sounds like the belt squealing is because it is the belt squealing. It is (or was in my case) caused by the harmonic balancer starting to fail. Apparently the resulting mis-alignment causes the belt to squeal. It can be quieted down temporarily by spraying water on it. And, as I said, the wobble to me was not noticeable or obvious, but it was enough to make the belt squeal. Belt dressing can also quiet it down, but if it is caused by the harmonic balancer, it will only be temporary, and it masks the issue.
Old Jan 29, 2025 | 08:49 AM
captain vette's Avatar
captain vette
If the noise went away,replace the belt?
how about those pulleys and idler that you can’t heard without the belt on
Old Jan 29, 2025 | 09:54 AM
hyperv6's Avatar
hyperv6
I don't hear anything. The balance looks ok but the camera moved so much.
It also can be attributed to glazing on pullies. and also alternators will make noise too.
Remove the belt or even put a little water on the belt to see if the sound changed. New belts on old pullies can squeak on the old rubber left behind by the old belts. V belts were bad for this and new serpentine belts it still happens.
Alt the pulley, bearing and clutch if equipped in the unit can do this.
Old Jan 31, 2025 | 05:01 AM
Moved to C5 Tech for more discussion.
Old Jan 31, 2025 | 09:18 PM
cdw's Avatar
cdw
I marked mine with a witness mark a couple years ago. would check it every now and then and it happened. marks were about 3 inches apart. I had the chirp. i'm about half way done now and will finish this spring. it's cold here and no heat in the garage.
To Bad C5 Harmonic Balancer?
