I have a 2004 Corvette Commemorative Edition coupe. The battery will not hold charge. I've replaced the battery twice in the last year.
I can't figure out what's going on. Any thoughts?
You will have to connect your DVM in series with the negative battery cable and negative battery terminal and select 10A scale to measure the current drain, should be around 25ma, you have to wait about 20 minutes. There is also a video showing how to measure millvolts across the fuses to find out what is causing the excessive current, there are several things in a C5, one of them being the seat module.
I will attest have same issue chased down to the drivers seat module drawing power. See my thread for all the details including how to check for a draw.
