FLP Owners Inside (problem)
Old Feb 10, 2003 | 11:57 AM
Mike TexaSS's Avatar
Mike TexaSS
Default FLP Owners Inside (problem)
I have herd about the issues with the flanges cracking or tearing off completely. Well this weekend i had my vette on our lift for some mods/maintaince. I replaced the left and right air dams. Very good mod IMHO my originals were tore up. And i got 2 new ones from Ken Fitcher Chevy for $13.00 :D .
I also put the cats back on the car. Then i noticed that the tab that bolts the collector to the body is cracked all the way around the weld. What do i do?
Im about to call FLP but want to here what other FLP owners did about this?
[Modified by Mike TexaSS, 10:59 AM 2/10/2003]
Old Feb 10, 2003 | 12:00 PM
SideStep's Avatar
SideStep
Default Re: FLP Owners Inside (Mike TexaSS)
ttt
:confused:
Old Feb 10, 2003 | 12:03 PM
Patches's Avatar
Patches
Your the second owner I've heard this has happened to and I'm curious as to the cause. Is it possible you bottomed out at one point and cracked them? There's a thread in general about the protrusion of the FLP's below the floor pan and concerns about scraping. Are there any scrapes on the collectors, clamps or cats that would indicate this could have happened?
I haven't had any problems to date with mine but would be interested in finding out if it's bad welds or lack of clearance.
Old Feb 10, 2003 | 12:09 PM
Mike TexaSS
Default Re: FLP Owners Inside (Patches)
No scrapes or dings. I belive the cause is just vibration. Just got off the phone with FLP and as soon as they are in stock (2 weeks) i will have a entire set sent to me no questions asked.
FLP Customer Service is AWSOME!!!
Plus the new headers have many new features over the Gen 1 that i have. Better placement of 02 sensor bungs.
[Modified by Mike TexaSS, 2:12 PM 2/10/2003]
Old Feb 10, 2003 | 12:25 PM
Patches's Avatar
Patches
Awesome! :cheers: Did they offer an explanation for failure of the welds due to vibration?
Apparently, FLP customer service is improving. :thumbs:
Old Feb 10, 2003 | 01:01 PM
kh24's Avatar
kh24
Good to know you got a set out that quick. Mine arrived damage and I was called a liar by them and ignored until I posted on the forum. They make a good product and know it looks like their customer service is backing it up. :cheers:
Old Feb 10, 2003 | 01:02 PM
rwj383's Avatar
rwj383
the exact same thing happened to me. tab ripped right out of the side of the collector around the weld on one side, and was about all the way off on the other. I had to take my headers back off, have the holes patched up, then i put them back on without these tabs.
The problem is that these tabs do not fit up to the bolts on the engine precisely. so if you force or bend or whatever to get the bolts into the tabs and tightened down, its only a matter of heat, vibration and time before the tabs tear off at the weldments. Do not use the tabs. not needed IMO. the exhaust is light enough and held up in the critical places as to not be a problem without the added support of these tabs.
Old Feb 10, 2003 | 01:06 PM
SideStep's Avatar
SideStep
I still say there should some kind of bushing or grommet between the header tab and where it bolts in. This would allow a little fudge room and absorb some of the vibration... FWIW :crazy:
Old Feb 10, 2003 | 01:11 PM
Patches's Avatar
Patches
Default Re: FLP Owners Inside (rwj383)
Robert, I had the same fitment issues with the tabs and was told by Dan Bills at FLP to draw the tabs up to the bell housing slowly. Eventually I did this and the tabs bent slightly and finally attached correctly. I've had the headers off several times since and, since the tabs are mild steel, they were permanently deformed the first time I bolted them onto the bracket and are no longer in tension when I reattach them. Granted, they didn't have far to go to get them lined up originally, but they fit nicely now with no signs of cracking.
I would imagine that it varies from header set to header set and from car to car.
Old Feb 10, 2003 | 01:50 PM
kp's Avatar
kp
If you loosen that bracket the tabs bolt to it has a lot of room to move around. My left side was at least a 1/2" off, the holes in that bracket are pretty big and it will move around quite a bit. When I had the corsas on the car when it idled with the cam they would vibrate a lot (them things are heavy) and you could see the x-pipe moving quite a bit. With the Ti exhaust the mufflers dont even move at idle, probably less strain on those brackets..
Old Feb 10, 2003 | 03:05 PM
C5Noir's Avatar
C5Noir
IMO, the tabs are useless. Has anyone tried to budge the header bolted up and leaving the tab bolt out? You can't move it. It's SOLID! I didn't even try mounting the bolts through those tabs after trying this.
Old Feb 10, 2003 | 03:10 PM
Mike TexaSS
Default Re: FLP Owners Inside (C5Noir)
Honestly i really dont want to remove and re-install the headers again. Especially for no real gain HP wise. I was thinking about cutting them off completely. And getting the small crack welded.
What will welding do to the coating?
Old Feb 10, 2003 | 03:13 PM
C5Noir's Avatar
C5Noir
It'll cause the coating to bubble and could evenutally prematurely flake off
Old Feb 10, 2003 | 03:21 PM
Mike TexaSS
Ok but it will stop the leak right? And we are only talking about a 1 inch weld here.
Old Feb 10, 2003 | 03:41 PM
C5Noir's Avatar
C5Noir
Oh yes, it'll stop the leak. I wouldn't do it though. I had a tack weld put on my old TPIS coated headers at the slip fit and it was causing my coating to start to flake off somewhat. Plus it looks hideous, IMO.
Old Feb 10, 2003 | 04:20 PM
Ram Air Tony's Avatar
Ram Air Tony
talk to Mitch at FLP....he will take care of you and make it right
mitch@flp2win.com
hope that helps
Old Feb 10, 2003 | 05:15 PM
SAXN8R's Avatar
SAXN8R
This happened to me. MTI and FLP took care of the problem at no cost to me! :D
Read: http://forums.corvetteforum.com/zerothread?id=472851
To FLP Owners Inside (problem)
Old Feb 11, 2003 | 07:11 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Sorry to hear of the break.
That is why I paid attention to the static fit of these tabs on my install page:
Maybe FLP will help with some labor costs :yesnod:
You could weld up the tab hole but it will destroy the coating and rust will follow.
IMHO, the tab needs to be there to minimize transmitting vibrations and to preclude loosening the clamp fastners........
[Modified by ALLTHROTTLE&NOBOTTLE, 7:29 AM 2/11/2003]
Old Feb 11, 2003 | 07:22 AM
Patches's Avatar
Patches
Default Re: FLP Owners Inside (ALLTHROTTLE&NOBOTTLE)
:yesnod: This is what I did. I screwed in all 4 bolts loosely and then slowly, sequentially tightened them as if I were tightening wheel lug nuts. That allowed the stress on the tabs and bracket to stay as neutral as possible once everything was tightened.
Old Feb 11, 2003 | 11:18 AM
rwj383's Avatar
rwj383
Patches is on to something. to take it a step further, you could cinch these tabs up to the bracket, the take a torch and heat the tab in the middle to flow the metal a bit. as it cools it will totally reform in its new position.
BTW, my tabs were so far off that any adjusting of the bracket itself wouldnt help.
Getting your holes/tears fixed will ruin the coating around that area. this pushed me to go ahead and wrap an otherwise beautiful header.
I dont worry about using the tabs because the system i held up quite sturdy at the x-pipe and, of course, the header attachment to the heads is extremely sturdy with the coarse thread header bolts. they arent going anywhere.
