Knightdrive TV bezel install
Old Apr 3, 2025 | 11:22 PM
SilverC54me's Avatar
SilverC54me
Originally Posted by Mr. Marbles
In the photo, the left light pod, which is closest to the center of the car, doesn't seat against the new bezel. Is this a matter of turning the shorter of the gold rods/aiming rods? Thanks everyone for the advice. I don't have FB anymore to see the videos that I hear Damien posted about the adjustments
The bezel appears to be correctly installed. There will be some gap between the light housing and bezel.
The alignment of the lights needs to be set before installing the bezels.
Gary
Old Apr 4, 2025 | 07:40 AM
Mr. Marbles's Avatar
Mr. Marbles
Thank you for the replies, I'll try to adjust the aim a bit to see if that helps the gap. I can't imagine that a gap that large is correct. Hopefully some penetrating oil will free up the frozen adjusters
Old May 15, 2025 | 06:29 PM
Spider978's Avatar
Spider978
Originally Posted by Traviper
I feel like a dumb dumb having to ask because it seems so strait forward. When installing the bezels they poke past the front bumper. They don’t line up with the two back screws where the headlight cover connects to the assembly. When they do line up, the bezel sticks out past the bumper. (picture below) Does anyone who installed them have any insight or run into any issues installing them?
Same exact problem im having. Its so frustrating reaching out to Damian at Knight Tv because he's never responded to any of my emails. Ive pre-ordered several products. Im having the same issue witht the bezels, were you able to get it corrected? If so, please share.
Old May 15, 2025 | 07:52 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
@KnightDriveTV
Old May 15, 2025 | 11:42 PM
jdmvette's Avatar
jdmvette
Night Owl for life
• your stops are adjusted too high.
• lower the overall light lift height by raising the jam nuts. the bezel then will not rise above the lip of the front bumper as yours are currently doing.
• at this point your light beams will be aimed too low, so use the goldenrod to raise the light modules back to the correct beam height.
• fixed.
Old May 18, 2025 | 10:59 AM
Moved to C5 Tech.
