110 octane
Old Feb 10, 2003 | 03:57 PM
smileyvette's Avatar
smileyvette
4th Gear
Default 110 octane
Where I live near Traveler's Rest in SC, the other day I saw 110 octane fuel at a Sphinx station. It was priced at $3.00. It said for off road race vehicles only, but interestingly enough, it had a corvette logo on the tank. Of course I didn't dare get any of this fuel, but I was just curious if such fuel could be used in an ordinary motor what it might do
Old Feb 10, 2003 | 03:58 PM
StickTail's Avatar
StickTail
Default Re: 110 octane (smileyvette)
Sunoco sells 110 at a few stations.
:chevy
[Modified by fdupny, 4:34 PM 2/10/2003]
Old Feb 10, 2003 | 04:00 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
This is an unleaded fuel?
vetterdstr :cheers:
Old Feb 10, 2003 | 04:14 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
First, you must make sure its unleaded fuel, or it will destroy your cats, and o2's.
Second, if you motor is of stock compression ratio, you may see a reduction in performance )especially with as much as 110), since higher octane fuel can slow the flame burn rate, it acts like timing retard on the motor.
Its best to use just enough octane, without getting knock.
If your getting knock on a stock compression motor, up to 93 octane, then you have other issues that need to be addressed, such has oil contamination, carbon build up, faulty knock sensors, etc.
Octane is simple a rating of a fuels ability to not pre-ignite under heat or pressure. It has nothing to do with a fuels ability to inherently create more explosive power.
[Modified by kewlbrz, 3:15 PM 2/10/2003]
kp's Avatar
kp
be careful, there are a few stations that sell 104 here and have unleaded nozzles but its leaded gas - I called the supplier because no one at the stations knew if it was leaded or not. There are a lot of lakes/boats around so I guess thats why they sell leaded..
Old Feb 10, 2003 | 04:16 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: 110 octane (vetterdstr)
if your car is stock do NOT run that high of octane in it.....
the more octane, the slower the gas burns, and in our cars, they are tuned to burn 91 to 94 octane, any higher, and you will lose power and create large amounts of unburned fuel which cause carbon deposits etc.
in my Z06, I can run like 104 octane, but it is tuned and has 11.0 to 1 compression, it likes race gas....my WS6 on the other hand, has stock heads and a big cam....I had to put some 104 octane in it (ran out) and it was a DOG .... it has 10.1 to 1 compression and tuning....it did NOT like it
dont run it in your stock car, it will slow it down
hope that helps
Old Feb 10, 2003 | 04:17 PM
Ram Air Tony
Default Re: 110 octane (Ram Air Tony)
kewl BEAT Me
dammit.....I wanted to break the news first :lol:
I must type too slow :banghead:
bewahhahehehehehhehe
thanks
R
A
T
[Modified by Ram Air Tony, 3:17 PM 2/10/2003]
Old Feb 11, 2003 | 03:16 PM
2kbluestreak's Avatar
2kbluestreak
I've also heard, but can't verify, that the computer regularly goes through a routine to see if the knock sensors are working. It intentionally bumps up the spark timing and waits to see if it gets a report from a knock sensor. If "yes", then no problem - system working. If you've got 100+ octane going through, there might not be a knock, so the computer figures the knock sensors aren't working and throws an error code. Can any C5 Tech's add to this? :cheers:
To 110 octane
