Proper way to fix the C1295 code
Old Feb 17, 2025 | 08:42 AM
oelarse's Avatar
oelarse
Default Proper way to fix the C1295 code
I have a friend getting this code C1295 after LED install .
The C1295 is caused by the EBCTM not getting between 1.8- 5.0 volt because LED has way less internal resistanse then the original high stop lamp.
I think by including a resistor ( 6 ohm 50w) like this downstream the lamp (green mark) will cure my friends C1295 alarm .
Am I correct ?
Old Feb 17, 2025 | 09:01 AM
lucky131969's Avatar
lucky131969
Am I correct ?
What is the measured voltage at the EBCM connector contact #6 with the brake pedal depressed?
Old Feb 17, 2025 | 09:13 AM
oelarse's Avatar
oelarse
I do not know. He is far away from me so am I not able to help him with any measurement.
But the Ebctm feed 5 volt to the high brake light when the brake pedal is not depressed.
And I guess a high brake lamp of LED will drop the 5 volt lower than 1.8 volt.
How does /where does other people with C1295 code add this resistor 😊
Old Feb 17, 2025 | 09:18 AM
lucky131969
.....some reading .....
https://www.corvetteforum.com/forums...install-2.html
Old Feb 17, 2025 | 10:56 AM
oelarse's Avatar
oelarse
I was was looking for some info on where people has placed the resistor and what resistance and watt size has been used
I have read that link above and some others , best is this one .
https://www.corvetteforum.com/forums/c5-tech/4651562-led-and-1295-a-2.html
Old Feb 17, 2025 | 11:12 AM
lucky131969
To Proper way to fix the C1295 code
