Accelerator pedal position test
Old Feb 17, 2025 | 03:40 PM
Johnnyv49's Avatar
Johnnyv49
Default Accelerator pedal position test
Can anyone point me to the process to test the APP while it's in the car? I believe it can be tested with a voltmeter. I searched everywhere but could not find any process that would work or where to test the plug at
Old Feb 17, 2025 | 03:45 PM
lucky131969's Avatar
lucky131969
What are you troubleshooting? The test typically tied to a TPS DTC etc.
Old Feb 17, 2025 | 05:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you have any APP DTC’s stored ??…a lab scope is preferred for testing but if you want to check it with a DVOM the signal wires are what you’ll be checking at the sensor…light blue, dark blue, and dark green…there are 3 potentiometers contained within the sensor…you have a 5 volt reference, signal, and sensor ground.
Old Feb 17, 2025 | 07:58 PM
Johnnyv49's Avatar
Johnnyv49
I was getting p1120 for TPS. This p1125 just showed up. Nothing is consistent unfortunately.
Old Feb 17, 2025 | 08:04 PM
C5 Diag's Avatar
C5 Diag
To Accelerator pedal position test
