Bilstein B6 are actually the first set of shocks I ever installed. My father is a retired mechanic, 77 years young now, can’t wrench, but is a helpful guide. Used the zip tie method to squeeze the rears in. And I have the Quickjack which my old man thought was an awesome piece of equipment. Good luck with the new shocks. And it’s a vette. Going to be a stiff ride regardless of what shocks you buy, unless you go with expensive adjustable shocks and put them on a soft setting.
Yes, I understand that. The DRM shocks are recommended for a lowered suspension so I need to investigate that further and see if I can lower it on the stock bolts or if aftermarket bolts are required and if so, if I'll have a clearance issue once lowered.
The shocls have shorter travels which prevent the shock from bottoming out.
These cars are 20 years old. I woould start with shocks, end links especially if your car has the stock early plastic end links, and tires if they are old or not as aggressive as you would like.
If you want a street car with stiffer sway bars after driving the car with fresh parts, C6 Z51, or Pfadt Johnny O'connell sways could be an option. Sway bar size, spring rate, and tire size all work together to control the over or under steer. C6Zs can be more agressive with the wider rear tires.
More titanium, by a lot and technically less material in the block
The block is aluminum and about the same weight. The LS7 did use titanium rods which are ~180 grams less per rod. So .4 lbs per rod. LS7 used sodium filled exhaust valves and titanium intake valves.
I dodn't see 20 lbs but the weight loss does help the motor accelerate faster and make controling the valve easier.
Even if it is 20 lbs, tire size plays a greater part in choosing shock valving, springs, and sway bars.
The weight difference with a LS7 vs. LS1 can also be due to the required dry sump setup, unless of course is a GMPP wet sump crate engine or say a LS3 based stroker engine. Either way the noted 20 lbs difference is minimal.
UPDATE:
So, as I had stated previously, I went with the B6 Bilstein's. Took me a while to complete the install, I ended up with tennis elbow and it postponed my install a few weeks. I also replaced all 4 sway bar links and the rear sway bar bushings. I am still getting the squeaking noise that started all of this!! At this point I believe I am going to have to replace the control arm bushings. For what its worth, the old shocks must have been shot because it does actually ride better, aside from the damn squeaking noise. Any recommendations on control arm bushing? This car does not get driven much, 3,000 miles/year and I do not track it.
Make sure to lube the front bar. Mine squeaked like crazy. I used Prothane lube and it took care of it. If you are still on the original bushings this is very common.
