those with a pro-torqe step inside
Old Feb 10, 2003 | 10:37 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default those with a pro-torqe step inside
How is this converter. I want to put a 2400 in my stock 98 C5. Any vibration problems?
Old Feb 11, 2003 | 01:06 AM
hogurt's Avatar
hogurt
Default Re: those with a pro-torqe step inside (rockgt302)
I can't say for sure. . .but I purchased one. I am going with the PT2900.
Old Feb 11, 2003 | 01:18 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
I had the 2800 No Vibe ,Great 60fts ,best 1.689. :yesnod: :yesnod: :yesnod: :cheers:
Old Feb 11, 2003 | 02:59 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
The PT-2400 was a great little converter, I had one for 2 years. I think I had a 60' time of 1.83, it does have it limitations, no vibrations.
[Modified by wallstAL, 12:00 AM 2/11/2003]
Old Feb 11, 2003 | 03:21 AM
MC98's Avatar
MC98
Default Re: those with a pro-torqe step inside (wallstAL)
:iagree:
I also had the PT2400 with 3.42 gears as Al said it is great little converter. It drives just like stock at normal speeds but still gives you alot more lowend grunt than the stock converter. However if you plan on racing your car alot or you will be doing H/C cam in the futher go with a converter with more stall.
98 A4
Donaldson Blackwing
Cartek Stage 2 Heads
Cartek M Cam
LS6 Intake
TPIS Headers
Underdrive Pulley
Comp Push Rods
Rev 1116 valve Springs
172 t.stat
Borla Exhaust
ST3500
3.73 Gears
B&M Trans Cooler
LS1 Edit Tuning
[Modified by MC98, 8:33 PM 2/11/2003]
Old Feb 11, 2003 | 12:55 PM
spdnman's Avatar
spdnman
I also have the PT2400 with 3.42 gears. I like this converter, but if I were to do it again, I'd go with a Yank 3500?. I drove forum member Redgar's modded Vette (385 rwhp) and it pulled away from a dead stop even more like stock than mine. I am looking for approx 360-380 rwhp soon and wished I had the Yank. Not sure of the correct model, sorry.
Old Feb 11, 2003 | 06:40 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: those with a pro-torqe step inside (spdnman)
I have the PT2400 in my car now, it's getting switched out for a bigger stall convereter in a week or two. Great street manners, see my sig for best times/60-foots with it. The only reason I'm going bigger is to try to squeeze another tenth or two out of my current setup. If you do a lot of street driving, you'll love it :yesnod: It will almost drive like stock until you hammer it.
Old Feb 11, 2003 | 07:43 PM
2001 Red Coupe Bandit's Avatar
Edgar, just FYI, has a ST3500, which is called a Yank SuperThruster. It has a STR or 2.4-2.5 depending on when you looked at Yank's web-site. Redgar likely also had DR's on his car when you drove it.
I would get a Higher Stall converter NOW and don't waste your time on a 2400 stall TC in MY opinion. PT makes a 2800-2900, that might be better.
The ST3500 Redgar has is more of a drag set up due to the high str, which stands for "stall torque ratio" and the ST3500 is more for a car that will see a pretty decent amount of drag strip time and is willing to run sticky tires, this TC would be hard to hook up on street tires. The SY3500 (SuperYank 3500) has a 1.61 str and is better for a mostly street driven car as the lower str will launch the car a bit softer, but you can still smoke the tires at will even with a SY3500..
Pro Torque makes a good product and I talked to the owner's son last year, he is a really nice guy, reminds me a lot of myself. :lol: I am personally getting a Yank, likely the SY3500 1.61 str and on a really off chance, a Yank ST3500 2.4 str or SS3600 2.6 str.
Good Luck in your decision. The PT2400 is a nice TC, but I bet you will want more very soon, but that of course depends on YOUR specific application for your Torque Converter.
The Bandit................. :cheers:
[Modified by 2001 Red Coupe Bandit, 6:50 PM 2/11/2003]
Old Feb 13, 2003 | 11:15 AM
BayouVette's Avatar
BayouVette
I'm intalling a PT2900 this weekend. If you want any info on its performance you can contact jpvette (John P. Harbour). I purchased it from him last month. I am installing other things also so I really would not be able to tell you the difference in the convertor alone..
Old Feb 13, 2003 | 12:02 PM
redbob's Avatar
redbob
I went from the stock converter to the PT2400-2900 (PT rates their converters by the amount of HP being applied) and 342 gears and dropped 9/10s of a second three years ago. I had the transmission rebuilt last year at 50,000 and sent the converter back to PT and they upgraded it to a 2900-3600 for $275.00.
To those with a pro-torqe step inside
