corvette said "kaboom"
Old Mar 5, 2025 | 11:29 AM
Gerdy_g06's Avatar
Gerdy_g06
4th Gear
Default corvette said "kaboom"
Hi guys so I am currently in need of a little help with figuring out what the problem could be but first I wanted to let y'all know how I got to this situation. I was at my local drag strip and I went in for my practice pass and I did my burn out no problem, I stage and launch and tires were spinning in first gear so i let off to get traction and then i go again, I shifted into second gear and i hear a loud boom and the car doesn't move anymore. i push the clutch to start the car and it will start but the problem is that i can go into any gear without pressing the clutch so I am confused on what I would need to replace. In my opinion i think that I might have snapped the output shaft or maybe the drive shaft exploded and i will need to replace the whole torque tube. if you guys have any other clues on what it could be please let me know
Old Mar 5, 2025 | 11:39 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
If you cannot see anything obvious by performing a visual inspection of the underside of the vehicle you will need to drop the driveline to figure out what you have damaged.
Old Mar 5, 2025 | 12:59 PM
mmartinez's Avatar
mmartinez
There is a small inspection plate on the bell housing that you can remove to inspect the clutch, and pressure plate. Since the car will not move and you can shift with out pressing the clutch, tells me you have a disconnect before the transmission or at the transmission.
Old Mar 5, 2025 | 11:35 PM
RC81's Avatar
RC81
Large boom's are never good. $$$$
Old Mar 6, 2025 | 11:20 AM
AtkRWC's Avatar
AtkRWC
Originally Posted by rc81
large boom's are never good. $$$$
this!
Old Mar 6, 2025 | 04:16 PM
hyperv6's Avatar
hyperv6
I wager coupler.
Corvettes will break these drag racing if stock and old or if you add power and keep them stock.
Old Mar 6, 2025 | 07:26 PM
493lszosix's Avatar
493lszosix
Broken output shaft on trans more than likely
Old Mar 6, 2025 | 10:28 PM
the_merv's Avatar
the_merv
Not the Output Shaft, he can get it into gear without the Clutch so it's before the Transmission.
Old Mar 7, 2025 | 09:06 AM
grinder11's Avatar
grinder11
I agree. Either a torque tube coupler or input shaft. I'd think after whatever blew/broke you'd hear some sort of clanking/grinding when engaging the clutch. I suppose something could've happened with the shifter that makes you think you're shifting into all the gears but actually aren't shifting anything, but I doubt it. Only reason I say anything about the shifter is that usually you can't find every gear without something spinning inside the trans. Usually there's a gear or two that stop the shifter from completely engaging them. Obviously the shifter didn't "boom," but there may be more than one problem here, IDK....
Old Mar 8, 2025 | 05:28 PM
TMODcustoms's Avatar
0TMODcustoms
Former Vendor
If you have to drop the tube consider upgrading your shift linkage.
TMODCUSTOMS Linkage Upgrade
To corvette said "kaboom"
