Randomly died yesterday??
Old Mar 14, 2025 | 06:40 AM
txkk626's Avatar
txkk626
Default Randomly died yesterday??
Just woke up my MY 2000 C5 after its 3-month winter nap on Tuesday. Started up strong, changed the oil, and have put 30-40 miles on it since. Yesterday afternoon, my son was driving it and it randomly died somewhere in between 30 to 40 mph. His report is that nothing seemed amiss on gauges or felt odd in terms of how it was running, but that it just shut off. He was able to stop and immediately it started right up again and drove it home without issue. Reviewed codes last night and saw no current codes. What should I be on the lookout for in trying to determine what happened?
Old Mar 14, 2025 | 09:40 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Possibly crankshaft position sensor but only a guess…this can be caused by a number of things as you can see in the video below…advanced diagnostic equipment is necessary so you don’t fire the parts canon.
Old Mar 14, 2025 | 09:44 AM
lucky131969's Avatar
lucky131969
History codes are relevant!
Old Mar 14, 2025 | 10:49 AM
txkk626's Avatar
txkk626
In that case:
28-TCS C1226 H
LF Excessive Wheel Speed Variation
A0-LDCM U1064 H
Loss of Communications with BCM
A1-RDCM B2265 H
Horizontal Position Sensor Fault
A1-RDCM U1064 H
A6-SCM B2606 H
Seat Rear Vertical Position Sensor Failure
B0-RFA U1096 H
Loss of Communication with IPC
B0-RFA U1064 H
Loss of Communication with BCM
B0-RFA U1016 H
Loss of Communication with PCM
Old Mar 14, 2025 | 10:50 AM
txkk626's Avatar
txkk626
Thanks for sharing that. I'll check it out!
Old Mar 14, 2025 | 10:51 AM
txkk626's Avatar
txkk626
https://youtu.be/pCn0ji6fuW8?si=s-ZuEknuvg1pRUt1
Thanks for sharing, I'll check that out.
Old Mar 14, 2025 | 01:49 PM
rrwirsi's Avatar
rrwirsi
I had a similar issue several years ago and my go to tech guy changed my ignition switch and have not had any further issues with the engine shutting down during driving.
Old Mar 14, 2025 | 01:55 PM
txkk626's Avatar
txkk626
Thanks for the tip! I'll look into that.
Old Mar 14, 2025 | 02:11 PM
lucky131969
Yep. Bad contact on the ignition switch will shut down the BCM, IPC, and PCM all at the same time.
To Randomly died yesterday??
