C5/C6 base springs
Old Mar 24, 2025 | 11:46 AM
h8snow's Avatar
h8snow
Default C5/C6 base springs
Would anyone know the difference between a C5 and C6 base suspension front springs? They have same casing numbers 22146483 but have different rates 440lbs vs 420lbs? Thanks.
Old Mar 24, 2025 | 01:22 PM
lucky131969's Avatar
lucky131969
https://www.corvetteforum.com/forums...atibility.html
Old Mar 24, 2025 | 01:41 PM
h8snow's Avatar
h8snow
Yes found that same posting also thanks. Confused about the casting numbers thought that how a person identified springs.
Old Mar 24, 2025 | 02:22 PM
lucky131969
It is. If I remember correctly, the C5 and C6 base use the same front spring 22146483.
Old Mar 24, 2025 | 03:39 PM
h8snow's Avatar
h8snow
Though so also same casting numbers 22146483. Everything I see online shows different spring rates 440lbs C5, 420lbs C6. FE1 suspension cars.
To C5/C6 base springs
