VMs bolt stuck on leaf spring
I’m in a bit of a pickle. As you can see, this aftermarket bolt is stuck, so much for an easy installation. I removed the upper control arm and sway bar pretty quickly, and I loosened the stock bolts. However, when I tried to put in the new bolt, it started screwing in but then as I was tightening the screw it got stuck. Do you have any tips? I’ve already tried using gripper pliers, but nothing seems to work. (Yes eventually I will upgrade coils)
Plz help 🙏
