Speed engineering headers extremely close to the starter
Old Apr 2, 2025 | 07:28 AM
Diydoidothisc5's Avatar
Diydoidothisc5
Default Speed engineering headers extremely close to the starter
I got a set of speed engineering headers and the clearance between the header primary tunes and the starter is no more than 2 or 3 credit card widths. Which from everything I can see is much closer than it should be. That being said i do have the two long bolt truck starter from a 2007 2500HD. I don't have the old one to compare does anyone know if the 2500 starter is any bigger than the original starter from everything I can see the two bolt starters aren't any wider than the original c5 starter. My question, Is the truck starter wider or if anyone else has had the truck starter and speed engineering long tubes how is the clearance for you.
Old Apr 3, 2025 | 12:32 PM
USN32's Avatar
USN32
I have ARH long tubes and a Bosch truck starter and the clearance was tight but not as close as you're describing. For peace of mind and heat protection I used this product from DEI https://www.summitracing.com/parts/d...2xoJT3qeS-DSbc as well as their wire protectors for anything that ran near the headers.
