Low-Speed Clunking Noise in Drivetrain
Old Apr 10, 2025 | 08:02 PM
kbuhagiar's Avatar
kbuhagiar
Default Low-Speed Clunking Noise in Drivetrain
Hello Folks,
Our 2004 LS1 six-speed has been making a 'clunking' sound when in gear and moving when either applying throttle or letting off the throttle at slow speeds. In the past this is exactly the sort of noise I would diagnose as U-joint wear, but as the C5 has transaxle architecture I am unsure. I put the car up on the lift but couldn't see anything apparrent, and because of the torque tube I couldn't just grab the driveline to attempt to replicate the noise.
I am familiar with legacy C2 & C3 driveline design but I am still behind on the C5; could this still be a u-joint? If so I would be surprised as I am the second owner, and the car only has 40,000 gently driven miles. Are there any other known possible causes for this clunking sound?
Thanks in advance!
Old Apr 10, 2025 | 10:19 PM
VettesRcool's Avatar
VettesRcool
Probably the torque tube needs rebuilding from what I've read. Not from personal experience.
Old Apr 10, 2025 | 11:43 PM
kbuhagiar's Avatar
kbuhagiar
So the rubber couplers in the torque tube break down over time and require replacement?
Old Apr 11, 2025 | 12:08 AM
Smoken1's Avatar
Smoken1
Check post 9 on this thread before you tear into the torque tube
https://www.corvetteforum.com/forums...ing-loose.html
Old Apr 11, 2025 | 08:55 AM
kbuhagiar's Avatar
kbuhagiar
Good info, thanks for that, I'll look into it, although my noise is definitely more of a clunk than a tap.
Old Apr 13, 2025 | 02:41 PM
TinkersVet's Avatar
TinkersVet
Have you checked the sway bar links. Worn out they give a klunk when off throttle. The OEM are plastic and give up after time.
Old Apr 13, 2025 | 03:14 PM
kbuhagiar's Avatar
kbuhagiar
I have not, was not aware. I'll look into that, thanks!
Old Apr 14, 2025 | 08:38 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Mine is an auto however whenever putting it gear I got a dull clunk. Suspected engine mounts were confirmed when a small brake torque while observing the engine showed it rocking excessively to the passenger side under load. I would check those and the rear diff mount at the cradle.
Old Apr 15, 2025 | 07:43 PM
Capt45's Avatar
Capt45
I am experiencing the same clunky sounds from the rear end area of my C6. Jacked up the car and took a look at the Sway Bar links and I think they are the problem. Sprayed both links liberally with Silicone spray and the noise has quieted down a lot. I'm ordering a set(Moog) for the rear and will install them next weekend.
Old May 7, 2025 | 05:05 PM
TinkersVet's Avatar
TinkersVet
Did you find out what the noise is??
Old May 7, 2025 | 05:42 PM
Capt45's Avatar
Capt45
Just got the Sway Bar Links and will get them put on when the weather cooperates. I took another look at the Sway Bar and measured it (1") with links that aren't OEM links, so this might be a crap shoot. Bushings looked relative new so I won't change them at this time.
Question: is the OEM Sway Bar a 1" bar? I'm finding other non OEM things on this "stock" C6, including Magna flo mufflers.
Old May 7, 2025 | 11:13 PM
kbuhagiar's Avatar
kbuhagiar
No, not yet...truth be told I got it up on the rack and then got pulled away by another project.
I hope to take a look at the sway bar links in the next day or two, but if they're OK I'm probably going to take it to our local Corvette mechanic, as I have no desire to mess with the torque tube.
Old May 9, 2025 | 08:35 AM
cdee63's Avatar
cdee63
25.4mm diameter rear bar? On a C6 that would be a Z51 bar.
Old May 12, 2025 | 06:13 PM
Capt45's Avatar
Capt45
Then that would be a add on to my base C6, along with the Magna Flo cat back setup. Wonder what else I'm going to find.
Old May 12, 2025 | 09:37 PM
Moved to C5 Tech for more assistance.
Old May 17, 2025 | 10:17 AM
VBMG@042021's Avatar
VBMG@042021
8th Gear
Hi there. I have a 03 C5 doing the same clunking. Took my car to a repair shop were the owner has some Corvette experience. After a test drive and getting on the lift pulling down the skid pan, it has been suggested to rebuild the torque tube. Good luck. Enjoy
Old May 17, 2025 | 10:26 AM
Capt45's Avatar
Capt45
Yikes; oddly enough I had a dealership replace the automatic shift cable (broken) and they of course had to pull the cover panel to get the cable on; however, my C6 was making the noise before the cable was replaced. I did spritz the Sway Bar end LInks good with a penetrating oil and the problem went away (wasn't a permanent fix) so I have end links to put on to replace the worn ones.
Old May 20, 2025 | 10:41 AM
JayhawkCPA's Avatar
JayhawkCPA
Torque tube or rear diff
To Low-Speed Clunking Noise in Drivetrain
