Rear Turn Signal Help
Old May 9, 2025 | 09:33 PM
novotnoa's Avatar
novotnoa
4th Gear
Default Rear Turn Signal Help
I know this has been talked about quite a bit but I’m having an issue I can’t fully comprehend.
Both front turn signals and drls are working (passenger hyper flash). Both rear brake lights are working, driver rear turn signal is working. Passenger rear turn signal is not working. Hazards work on all lights however with no hyper flash. I’ve put new bulbs in and the sockets seem fine visually, and they work for the other lights so I imagine that’s not a problem.
Reading previous threads it seems like it must be the hazard switch or MFS. Pressing the hazard switch repeatedly does nothing and I would think the brake lights would be out if it was that one. So I’m thinking MFS. I don’t know why the front bulb is working but hyper flashing if that was the case though, and I also read someone say that hyper flash is always a bad bulb or socket, which it doesn’t seem to be in this case (all brake lights and hazards work as intended).
Is there a way to test these switches for my problem? I don’t want to blindly through parts and time at the car if I don’t have to. I also don’t want to pay someone to do the same thing. Thanks!
Old May 10, 2025 | 08:11 AM
redzg's Avatar
redzg
Several of the existing threads have the relevant wiring diagrams attached to help you follow the current paths. My C5 experience with both brake lights and turn signals has led to the hazard switch, though I do have a spare multifunction switch in the cabinet. In non-C5 experience tail light issues have been poor grounding almost every time.
Old May 10, 2025 | 09:15 AM
lucky131969's Avatar
lucky131969
New bulbs as in what type? LED? Incandescent? What is the history here?
Old May 10, 2025 | 12:55 PM
TonyCorvette_'s Avatar
TonyCorvette_
Your issue isn’t MFS- it doesn’t distinguish left from right for the turn signals. I’d start by replacing all four turn signal sockets and oem rated bulbs. If that doesn’t resolve it, start tracing wires.
Tony
Old May 12, 2025 | 07:59 AM
novotnoa's Avatar
novotnoa
4th Gear
All Sylvania incandescent bulbs. Every turn signal bulb has been changed at this point with the correct OEM equivalent.
Old May 12, 2025 | 08:06 AM
novotnoa's Avatar
novotnoa
4th Gear
Tony
Okay I will grab a friend to test the sockets with a multimeter tonight. They’re dual filaments obviously, but are the hazards on the same filament as the brake lights, or are they on the same as the turn signals? I guess I’ll find out tonight regardless, but if the hazards are on the same filament as the turn signals then the sockets wouldn’t be the problem because those work.
As for wires, the same question applies. Thanks for the help! I will report back with results.
Old May 12, 2025 | 01:11 PM
Dads2kconvertible's Avatar
Dads2kconvertible
I'd use a test light. Connect the clip end to a good ground and probe all the connections while the signal is on. If it starts working you have a bad ground.
Old May 13, 2025 | 03:22 AM
LWSZ06's Avatar
LWSZ06
The Stop/Turn Lights and the Hazards all use the same (high watt) filament of the bulb. The Park Lights use the low watt filament.
Old May 19, 2025 | 01:46 PM
novotnoa's Avatar
novotnoa
4th Gear
Sorry I haven’t been able to do my diagnostics yet as I’ve been busy. Since they use the same filament that would mean my sockets are fine correct since brake lights and hazards work fine?
Old May 20, 2025 | 11:55 AM
Eliot Ness's Avatar
Eliot Ness
.........Both front turn signals and drls are working (passenger hyper flash). Both rear brake lights are working, driver rear turn signal is working. Passenger rear turn signal is not working. Hazards work on all lights however with no hyper flash. I’ve put new bulbs in and the sockets seem fine visually, and they work for the other lights so I imagine that’s not a problem.........
The system hyper-flashes to indicate a burned out bulb. I believe the turn signals and the hazards work off different flashers. I say that because when you install LED bulbs and a hyper-flash harness the hazards will still hyper-flash. Hopefully someone will correct me if I'm wrong. If the hazards work then it sounds like you have something funky between the normal flasher and your bulb. I'd double check the grounds in the rear and replace or at least clean and re-seat the flasher. Do a search on installing a hyper-flash harness and it will show you where all that is located. Good luck and report back what you find.
Old May 20, 2025 | 12:49 PM
lucky131969
Originally Posted by Eliot Ness
I believe the turn signals and the hazards work off different flashers. .
Nope.
To Rear Turn Signal Help
