c5 base tach issue
Old Apr 16, 2025 | 03:08 PM
dddd's Avatar
dddd
3rd Gear
Default c5 base tach issue
why isn't my tach going above 2000 rpm on my 2000 c5
Old Apr 16, 2025 | 03:14 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
When you sat the tach won't go over 2000, is it the tach needle itself or it the tach indicating the engine itself won't go over 2000?
Old Apr 16, 2025 | 03:17 PM
dddd's Avatar
dddd
3rd Gear
Sorry about that. The needle, engine runs strong.
Old Apr 16, 2025 | 03:29 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Either a wiring issue or a bad IPC…sounds like a bad IPC.
Old Apr 16, 2025 | 03:40 PM
dddd's Avatar
dddd
3rd Gear
Thank you, I'll look into this
Old Apr 17, 2025 | 07:37 AM
Ark1228's Avatar
Ark1228
Might be a good read.
https://www.corvetteactioncenter.com...nosis-385.html
Old Apr 19, 2025 | 06:26 AM
Moved to C5 Tech.
To c5 base tach issue
