So, I'm doing with tracking my Z. It was built well for that purpose. But I'm thinking (I know, a dangerous pass time...) that rather than sell it as the track beast that it is, that rather I might hang onto it and continue to enjoy the car... So, I've got the control arms out and the bushings (which were a stiff poly) look a bit scored. They were squeaking before I pulled them out. The scoring took me by surprise. Normal?
Anyway, because there is some much collective knowledge and experience here in the Forums, I thought that I'd ask for your thoughts about the bushings. Keep (lubricate, of course), or replace. If replacement is the better path, what would you replace them with?
Thank you very much for your thoughts and feedback on this post!
Do the control arms have grease fittings for the bushings? If they don't you can expect to see bushing wear as any initial install grease thins out and escapes. The same is true for the sway bar bushing mounts. If the bushings aren't too worn then they can be cleaned and reused with new grease. With grease fittings you can give the bushings a shot of grease once or twice a year and not hear any squeaking.
No, the control arms do not have any grease fittings. I wonder how that would even work since the bushings are stationary within the control arms. Is the grease supposed to spread out between the outer wall of the bushing and the inner wall of the control arm? The squeaking that I'm hearing is coming from the face of the bushing rubbing against the face of the mounting bracket. Seems like a strange piece of engineering...
Thank you... That's pretty much the way I'm leaning at this point. Keep the car, make it a bit softer (so that the Misses will come along), and leave an antique to the kids years from now.
From memory: After the bushings were installed, a tap hole was drilled into the arm/ bushing and tapped for a grease fitting. A small 1" diameter grinding stone was used in a Dremel to create a shallow internal circular groove where the bushings meet then all was flushed clean. If the installed bushings don't contact each other on their inner side a groove isn't needed because the grease can circulate in the space between the bushings. Mine did contact each other so the grease fitting is in the arm center line and the hole goes through half of one and half of the other bushing. So the grease under pressure goes through the fitting, through the hole in the bushing(s) and around the center shaft from the circular groove then out of the ends. I think silicone grease is recommended for this application.
That is very clever. So, to make sure that I understand, the hole that was drilled through the control arm continues through the bushing and through the inner metal sleeve of the bushing. You then ground out a shallow swale perpendicular to the long axis inside the metal sleeve in the bushing. Now when grease is pushed into the fitting, it goes into the core of the sleeve and around the bolt. It can travel down the bolt and exit on the ends of the bushing. Do I have that right?
The hole didn't go into the center hollow aluminum spacer, the groove in the poly bushing went around the spacer not along it so the grease goes around the center spacer half way from each end. The hollow aluminum spacer becomes lubed with grease where it rotates in the poly bushing and the grease flows out to the sides.
