Valve Train Tick Diagnosis
Old Apr 21, 2025 | 06:48 PM
milkyc5's Avatar
milkyc5
Default Valve Train Tick Diagnosis
2000 base model. Auto transmission. Bone stock.
Recent maintenance:
- Spark plugs
- Spark plug wires
- AIR system vacuum repair
- Valve cover gaskets
- Intake gaskets
- Oil pressure sender
- PCV hose leak repair
- Vacuum leak test passed (Propane torch method)
- Oil Mobil 1 5W-30, AC delco OEM filter
A week ago I noticed a light ticking noise coming from my engine. Driven approx ~100 miles since start of ticking.
Characteristics of the tick:
- Does not go away when engine warms up
- Sound frequency seemingly synchronizes with exhaust sound (pretty on point)
- Seemingly coming from passenger side up top end
- Tick speeds up with engine speed
- Tick noise increases sound when rev drops from a 2krpm throttle blip
Other current symptoms:
- Idle is somewhat “jittery” will be constantly floating from ~625rpm to ~575rpm
- No check engine light
When I take off the valve covers, how should I go about inspecting for any failed parts? Ofcourse i’m going to look for the obvious, but any less obvious tell tales of a valve train failure somewhere?
Old Apr 21, 2025 | 09:11 PM
99FRC Newb's Avatar
99FRC Newb
Every LS engine I’ve ever owned has had a lifter tick. That is likely what you are hearing. You can narrow it down with a “mechanics stethoscope.” $9 from Harbor Freight.
Old Apr 22, 2025 | 03:39 AM
milkyc5's Avatar
milkyc5
Okay so if it’s just a “normal” LS lifter tick noise, how come it’s now much louder than before I did an oil change? I’ll triple check for an exhaust manifold leak, but I highly doubt it
Old Apr 22, 2025 | 08:32 AM
lucky131969's Avatar
lucky131969
Really important to be distinct in what a diagnosed "lifter tick" actually is, and normal valvetrain noise for an LS engine.
Old Apr 22, 2025 | 08:33 AM
lucky131969
If in any doubt, take it to a trusted shop....you will not always get the best answers on a forum.
Old Apr 22, 2025 | 11:27 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just curious.....what oil did you have in the engine before the "lifter tick", and what oil is in it now?
Old Apr 22, 2025 | 04:17 PM
milkyc5's Avatar
milkyc5
I just got this car so the previous owner had the engine oil changed at a valvoline the day before he sold it to me. Carfax reflects that maintenance as well. And after about 1800 miles, not a noticeable tick, and now there’s a loud tick after I put AC Delco OEM filter and Mobil 1 5W-30 as stated in my original post.
Old Apr 22, 2025 | 04:39 PM
silverja's Avatar
silverja
Default Post a video
Very hard to diagnose noises when in writing. Take and post here a short video using your phone with hood open on a cold start and then afterward warming up. My 2 C5's are noisy on cold start that is normal LS1 piston slap. Quiets down after a few miles or when reaching normal operating temperature. Many first time owners panic while there is no real option to eliminate based on my extensive research. Tread carefully if looking for correction when dealing with mechanics unfamiliar with C5 Corvettes. Good luck resolving this concern.
Old Apr 23, 2025 | 08:00 AM
leadfoot4's Avatar
leadfoot4
The reason that I asked about the oil, was because about 10 years ago, I had a part time job at my area's Advance Auto Parts store, and we were running a "closeout sale" on a particular 0W-40 Castrol Edge oil. I thought I'd try it, as I was putting my C-5 back on the road for the summer, and an oil change was due. I warmed up the car and drained the old oil, most likely Mobil1. I refilled the car with the Castrol, fired it up, and IMMDEIATELY the lifters were "clicking". I let the car run for maybe 5 minutes, or so, just to make sure that the oil was fully circulated throughout the engine.
The clicking didn't stop, so I backed the car back up on my ramps, changed the oil back to Mobil1, and the clicking immediately disappeared. It will be interesting, this year, as I have a small supply of 5W-30 Pennzoil Platinum, left over from a car we no longer own, that I want to use up, rather than let it sit, collecting dust. I hope that I don't go through the same scenario as I did with the Castrol.....
Old Apr 24, 2025 | 01:29 AM
milkyc5's Avatar
milkyc5
Heres a cold start. I’m just looking at an idea of what I might need to order before I rip off the heads so I’m prepared. Either way, the heads need to come off to look at the cam, lifters and valve train, etc.
Old Apr 24, 2025 | 08:46 AM
lucky131969
oh boy
Old Apr 24, 2025 | 03:30 PM
milkyc5's Avatar
milkyc5
Originally Posted by lucky131969
oh boy
Most likely some lifters to be repaired, don’t ya think
Old Apr 24, 2025 | 03:55 PM
lucky131969
No idea. I cannot gleam anything from the video taken that perspective, hood down...etc. What have you done to isolate the noise? Removed belt? Mechanics stethoscope?
Old Apr 25, 2025 | 02:07 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Having just listened to another thread with the same question where the noise is very low from very up close, hearing this one from 8 feet does sound at least in the audio clip to be metallic in nature. Only sounds like one. But one "something" is saying it needs a little attention.
Definitely do follow through on using a mechanics stethoscope as it will allow you to localize the noise. Is it inside a valve cover? Which side? Which end? It will be apparent if it is. The suggestion to remove the accessory belt is an easy and quick one also just to be certain. Just remember you cannot idle the car forever on your battery alone, LOL.
Why were the valve cover gaskets and intake gasket replaced? That one perked my attention.
Old Apr 25, 2025 | 03:37 AM
milkyc5's Avatar
milkyc5
I used my mechanics stethoscope and when I’m underneath the car and probe it to the block/head driver side, the ticking is the loudest
Old Apr 25, 2025 | 03:40 AM
milkyc5's Avatar
milkyc5
Using the mechanics stethoscope during idle, I hear it the loudest at the head and block driver side. The Valve cover gaskets were replaced because there was a bunch of gunk around them most likely indicating they were leaking
Old Apr 25, 2025 | 04:45 AM
frodo84's Avatar
frodo84
Uneducated autodidact
I would take off the driver's side valve cover and look for broken valve springs first. If none are found, an old mechanic's trick would be to have someone start it up with the valve cover off (I know, it will be messy even at idle so have a lot of shop towels laying below the head) and take a big screwdriver (or something) and push down on each rocker at the pushrod end, keeping pressure on it while listening for a change in the noise. I've done this myself, and was able to get a lifter to pump up in a truck engine that had sat for a long time. It saved me from pulling the heads and I put another 50k miles on it before I sold it. Just an idea, good luck.
Old Apr 25, 2025 | 09:30 AM
Tusc's Avatar
Tusc
Frodo's still in here knockin' out fixes. Haven't seen you around in a bit. Glad you're still around!
To Valve Train Tick Diagnosis
