I know this has been asked 1000 times but I feel like I’m close to figuring out my problems.
My multimeter is showing .27 draw on my battery when it’s asleep. I also had the driver door lock that would intermittently lock when I used the fob. I’ve determined that the door module needs to be repaired so I ordered a replacement. With the door module removed, I’m still showing the .27 draw on the battery so I’m ruling that module as the issue.
is there a chance the BCM itself needs to be repaired/replaced? I did notice I had a false read for tire pressure today also so it makes me think the BCM is just bad.
I pulled every fuse for the BCM, then pulled for Bose speakers, then just tried pulling a few random fuses. I even disconnected the BCM and it never budged. Still showing a .27. Does this tell me anything now that I can rule out that it’s the BCM?
You have to first isolate the current drain source to the engine fuse or interior fuse box. The first step thou is to disconnect the two cables on the engine fuse box you can access by removing the fuse box cover. One cable is the supply cable the other is the feed to the interior fuse box, check the current drain if excessive then that means your alternator is at fault. If alternator is not causing current drain then proceed with voltage drop measurement at engine fuse box with interior fuse box left disconnected.
