SKF bearing comparison
Old Sep 24, 2025 | 11:54 AM
Midwayman's Avatar
Midwayman
Originally Posted by Tusc
X-Tracker vs base?
I'm not the one with all the input on these but the gyst of it is that the X-tracker survives a lot more abuse from racing slicks and heavy braking without having to be replaced for a longer period of time.
I have seen some racers argue that the X-tracker is a must for the rear but that a lesser piece can be used in the front for track cars.
For a street car I don't believe it will be necessary. We're just not abusing the car as hard or for nearly as consistently long as on a track no matter how aggressive we think we are being.
You have that backwards. The rears have axle support and the cheaper MPI's work fine. The front aren't as well supported and the MPI v1 experience some leaking. However there is a v2 out there.
If you don't autox or track you'll probably be fine with basic bearings. If you don't want to have to do the job again I'd probably spring for at least the MPI bearings. Replace them in pairs though. The zr1 style flanges are a little thicker.
Old Sep 25, 2025 | 04:05 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Thanks for the correct info
