Headlight help please
Old Apr 28, 2025 | 07:03 PM
G Man's Avatar
G Man
Default Headlight help please
I just completed the install of both new headlight motors. I also added LED bulbs since I was in there along with new turn signal housings and LED’s.
When I turn the stalk to turn on the headlights, both headlights raise, and the bulbs illuminate. When I turn the headlights off, they will not close and the lights do not turn off. I have to manually close the headlights and unplug the harness to turn the headlights off. The other weird thing is that with everything unplugged, light stalk turned off, the interior chime is audible when I open the door (no keys in the ignition).
Any ideas? (Yes, I searched). Thanks in advance.
Old Apr 28, 2025 | 08:47 PM
kenbikeguy's Avatar
kenbikeguy
You are going to need one of these.
97-04 Corvette Hyperflash Harness Corvette Parts Center
These are available from multiple vendors not just from the link above.
The other way is turn on you bright lights then turn off the lights. The electrical system does some weird things with the LED bulbs installed. I still have to turn on the brights sometimes and then turn off the headlights even with the harness.
Old Apr 29, 2025 | 08:02 PM
G Man's Avatar
G Man
Thanks. I just put all factory bulbs back in. Issues resolved. I’ll explore the LED mods later.
Old Apr 29, 2025 | 08:10 PM
sonicss33's Avatar
sonicss33
If you do a search here on anything headlight related I can assure you this: you will be overwhelmed and more confused than you ever thought was imaginable.
To Headlight help please
