Quick A4 question..
Old Feb 12, 2003 | 06:26 PM
FarmerBob2001's Avatar
FarmerBob2001
Default Quick A4 question..
Say the max speed in 2nd is 80mph (just an example number). Say you're doing 100mph in 'D'.
If you go to downshift to '3', and accidentally go through '3' and land in '2', will the computer be smart enough to keep you in 3rd until your speed drops to 80mph or less, or will it just throw you in 2nd and over-rev the engine?
Thanks.
Old Feb 12, 2003 | 06:31 PM
402Sam's Avatar
402Sam
Default Re: Quick A4 question.. (FarmerBob2001)
I am telling you this from experience. I have accidently did something like this, if you are a greater speed then the gear allows you to it will stay in D until you get to a speed where it can shift down w/o redlining. So you would be alright if you hit the shifter on accident of something. :)
Old Feb 12, 2003 | 06:35 PM
Carvettejal's Avatar
Carvettejal
I'm pretty sure I did this once and it did over rev. When your in 2d your in 2d. I'm sure it's the same as leaving it in 2d and not up shifting...it over-revs. FYI 2d will take you up to ~104.
Old Feb 12, 2003 | 06:36 PM
FarmerBob2001
Default Re: Quick A4 question.. (sprayedc5)
Thanks. That's good to hear.
Old Feb 12, 2003 | 06:41 PM
FarmerBob2001
Default Re: Quick A4 question.. (Carvettejal)
Well, now I'm getting conflicting info.. :confused:
I know if you start in 2nd (from a stop) you will get 2nd and 2nd only. But the same question applies to 1st and 3rd. If you're doing 200mph in 4th (say you own a Lingenfelter..) and move the lever into '3', what happens? I hope the computer is programmed to keep it in 4th to avoid engine damage.
Old Feb 12, 2003 | 07:01 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Quick A4 question....
I've got a pretty quick A4....whatcha need :jester
Old Feb 12, 2003 | 07:44 PM
Carvettejal
SprayedC5 is exactly correct...I meant you hit the rev limiter not over rev.
Old Feb 12, 2003 | 07:52 PM
RskyBns's Avatar
RskyBns
I hear the conflicting stuff.....maybe it's different between the years of the C5? Like Pre-2001 and 2001+ ?? I dunno....just a thought. I'm curious as well as I have no clue. :D
Old Feb 12, 2003 | 08:23 PM
Untouchable00's Avatar
Untouchable00
Default Re: Quick A4 question.. (RskyBns)
Lingenfelter reprogramms the computer, but you will hit the lmiter, anyway.
Old Feb 12, 2003 | 09:02 PM
pasender's Avatar
pasender
Default Re: Quick A4 question.. (Untouchable00)
I tested that last week-end at Laguna Seca, where you reach 120 in 3rd at the end of the stands and i put it back in 2nd and it does NOT downshift until it is safe to do so (I have a 98 A4 2.73), while i'm braking.
Same thing for 1st gear, it will only shift back when safe.
Old Feb 12, 2003 | 09:27 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Default Re: Quick A4 question.. (pasender)
>>>I tested that last week-end at Laguna Seca, where you reach 120 in 3rd at the end of the stands and i put it back in 2nd and it does NOT downshift until it is safe to do so<<<
Yep, what he said. Computer controlled automatics have had this safety feature for quite some time. Think about what would happen if this weren't the case. You are way above the rev limiter range for a particular gear. You drop it down and it downshifts to that gear.
The rear wheels would, most likely, lock up in a massive skid and at the same time attempt to over rev the engine. The rev limiter can't help this situation because the differential is manually rotating the engine.
So in this case it is computer to the rescue. It knows the safe speed to allow the kickdown to occur.
Just don't try that scenario in a manual!!!
[Modified by 2k2C5, 8:45 PM 2/12/2003]
Old Feb 12, 2003 | 09:30 PM
402Sam's Avatar
402Sam
And I thank you :D
Old Feb 12, 2003 | 11:06 PM
hogurt's Avatar
hogurt
Yep, I have tested. It won't downshift.
Now, what happens if you have a shift kit??? Mine will be installed in a few weeks.
Old Feb 13, 2003 | 12:25 AM
gojo's Avatar
gojo
Default Re: Quick A4 question.. (hogurt)
The shift kit will change the shift times and shift firmness, only.
Old Feb 13, 2003 | 10:35 AM
HOTSOSS's Avatar
HOTSOSS
Default Re: Quick A4 question.. (jfpilla)
Farmer, why don't you test it by going maybe 1 mph over your shift point and put it in 2nd and see what happens. Can't hurt anything doing it that way. :cheers:
Old Feb 13, 2003 | 11:24 AM
cscollis's Avatar
cscollis
Just get you shift points up/down corrected using ls1edit and you dont need to manually shift. Setup the down shift to the exact same as the up shift and just floor it and your money!
Old Feb 13, 2003 | 01:03 PM
FarmerBob2001
Default Re: Quick A4 question.. (2k2C5)
That's what I was hoping to hear. Thanks..
To Quick A4 question..
Old Feb 20, 2003 | 08:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If you are going forward at about 30 mph and put the selector into Reverse, the computer will NOT prevent the trans from shifting into reverse, or at least trying to. :eek:
Don't ask how I know.....
Old Feb 20, 2003 | 10:33 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Re: Quick A4 question.. (Gearhead Jim)
:eek: :eek: :eek:
Old Feb 20, 2003 | 10:53 PM
hogurt's Avatar
hogurt
Default Re: Quick A4 question.. (cscollis)
:nono: That depends on how much power your car has. . .better be careful. If have the car in OD. . .and you floor it, the A4 will try to shift from 4th to 2nd. . .if you have too much power you'll be sideways real quick! That is one big advantage of having the shift kit. You can control the shifting and only drop it to 3rd. . .this is especially true when coming off of a hard corner.
