I need an ABS module for my 03. Having trouble locating one. Any ideas?
If you are looking for NOS, then I see the complexity. If you are looking for used, or used-refurbished....there are plenty of choices. Did you do a simple Google search for 2003 Corvette EBCM?
I just searched ABS module. I was looking for a new oem but I see that is not available. Now trying to figure out a best 2nd choice. Buying used or trying to have it repaired.
Well, I assume that you have done the necessary troubleshooting down to EBCM level, and you have a problem that is repairable.
I have. I was told mine is not repairable. It is no comm and has shut down the entire system. Also BCM is dead. Possible lightening strike. Looks like I need a used one.
