Help
Old May 22, 2025 | 01:01 PM
tglock's Avatar
tglock
2nd Gear
Default Help
Hello, I have the dreaded service active handling, traction system abs fault. Showed up after replacing rear disks and pads .Did I break something?
Old May 23, 2025 | 12:07 PM
MetalMan2's Avatar
MetalMan2
There's a wheel speed sensor in each wheel hub and those have a wire connector. Perhaps something happened to one of those.
Check your fault codes from the DIC and report back.
Old May 24, 2025 | 09:43 AM
tglock's Avatar
tglock
2nd Gear
Default Sensor
Yes , the sensor was unplugged and corrected the issue. I didn't investigate far enough before posting. My bad. Thanks.
Old May 27, 2025 | 12:53 AM
Moved to C5 Tech for assistance.
To Help
