Grinding noise from transmission
Old May 31, 2025 | 01:48 PM
XavierDav's Avatar
XavierDav
2nd Gear
Default Grinding noise from transmission
Recently started getting this grinding noise from the transmission and I will lose all my gears. The noise goes away if I let the car sit while off for like 5m then it will come back a couple minutes later. I suspected it was a clogged filter and replaced filter and gasket which solved the problem but couple days ago I wanted to verify my fluid level so I popped the fill plug out of the transmission (while the car was off) I was being dumb and a lot of fluid came out as suspected because the car was off but riding home I felt hesitations at 65mph then lost all my gears and have the noise back again. I thought it was because I was low on fluid from when I loosened the fill cap while the car was off and let a lot of trans fluid leak out, so I added some fluid which took a good amount but I still hearing the noise. Could the filter be clogged again, somehow? Or is it another issue?
File Type: mov
