Popup headlight haywiring
Old Jun 14, 2025 | 03:43 PM
ellanoz's Avatar
ellanoz
Default Popup headlight haywiring
As the title suggests, my pop-up headlights started going crazy yesterday afternoon. When I turn on the foglight, both headlights popped up (which is not supposed to happen), and when I turn all lights off the headlights went down normally for a second. The driver side headlight popped back up and down four times in a row before it popped down one last time. Everything returns to how it should be .
Going through a few threads it seems like a brass gear issue but I just want to double check if there is a sensor somewhere I should touch before taking apart the headlight motor. I've already turned Twilight Sentinel mode a long time ago and just replaced the rubber bump inside the headlight about a month ago, no creaking sound, also apart from how haunted the headlights are now.
Old Jun 15, 2025 | 08:37 PM
ellanoz's Avatar
ellanoz
Anyone? Ordered brass gear from Rodney but seems like there are also threads talking about headlight control module and headlight switch...
Old Jun 16, 2025 | 12:57 AM
Dads2kconvertible's Avatar
Dads2kconvertible
What codes are being set?
Old Jun 20, 2025 | 07:38 PM
xcarter's Avatar
xcarter
Gears and bump-stops (there's three or four per light) would be my first step, that resolves these issues most of the time.
Old Jun 22, 2025 | 08:15 PM
ellanoz's Avatar
ellanoz
Replaced the gear and the bump, issue solved, great thanks to those who replied👍🏻
To Popup headlight haywiring
