Weird Headlight Problem - Stuck and Clicking
Old Jun 15, 2025 | 11:32 PM
chnco's Avatar
chnco
8th Gear
Default Weird Headlight Problem - Stuck and Clicking
I assumed my gears were bad so I went ahead and replaced both headlight motors. After replacement, they worked fine, but after 3-4 times using them, I am noticing my headlight are stuck up or down, regardless if I manually move them up/down
I’m also hearing a faint clicking noise from passenger motor and my headlights bulbs are actually stuck on, regardless if I have my stalk on or off.
I have checked fuses 3 and 4 under hood, no issues, my next guess is to replace headlight controls module.
Anyone run into this issue and have suggestions? Thanks!!
Old Jun 16, 2025 | 12:44 AM
Moved to C5 Tech.
Old Jun 16, 2025 | 10:27 AM
Markmbaha1's Avatar
Markmbaha1
If you thought the gears were bad i hope you replaced the gears and motor. They are now likely completely oit of alignment and possibly replace the gears again.
Old Jun 16, 2025 | 10:51 AM
chnco's Avatar
chnco
8th Gear
I replaced the entire motor with new units, so should be good here
Old Jun 17, 2025 | 09:24 PM
chnco's Avatar
chnco
8th Gear
Update, I replaced the headlight control module and it didn’t fix it.
it did randomly go up from down position when I powered the car off…
Old Jun 19, 2025 | 05:44 PM
Alley Oop's Avatar
Alley Oop
Did you check your bump stops?
Old Jun 20, 2025 | 12:09 PM
xcarter's Avatar
xcarter
Plus one to this. My friends who have done this say replacing the three bump-stops is as important as replacing the motor to make this fix work
To Weird Headlight Problem - Stuck and Clicking
