Telescopic steering column
Old Jun 24, 2025 | 08:18 AM
Clayton59's Avatar
Clayton59
Default Telescopic steering column
My column is all the way in to the dash and will not come out. When I use the button there is a click that sound almost like a relay click but the column does not move. Is there a manual way to move the column out?
I have looked through the forum threads and cannot find what I'm looking for.
Any advise is helpful.
Old Jun 24, 2025 | 04:18 PM
DetroitGS's Avatar
DetroitGS
The switch isn't difficult to replace if it failed. Make sure the wiring harness to your driver's seat is plugged in and/or not damaged. The module for the telescoping column is under the seat and is part of the seat harness. Does your power seat work?
Old Jun 24, 2025 | 08:29 PM
Clayton59's Avatar
Clayton59
yes, power seats work as they should.
Easy in/out: Seat works, Telescoping column does not.
Is there a way to manually get the steering wheel to come away from the dash?
Old Jun 25, 2025 | 06:00 PM
DetroitGS's Avatar
DetroitGS
I don't know the answer, if it's possible or not.
Old Jun 26, 2025 | 07:48 AM
drtyTshrt's Avatar
drtyTshrt
Engage the switch with some force. More than just a regular pull.
Click it back and forth a few times or when ever possible.
Mine was finickie but I never had to replace it.
I do not think it can be moved manually.
To Telescopic steering column
