Replacing A/C Compressor
Old Jun 26, 2025 | 12:40 AM
Hotrodzz3's Avatar
Hotrodzz3
Default Replacing A/C Compressor
My car has given me the sign that I will be replacing the A/C compressor very soon (big puddle of oil on the floor) so I've started to look for the parts that I'm going to need and everyone is telling me that I can no longer get an original GM compressor. I really hate the idea of putting 3rd party parts (chinese junk) on my car so what I'm looking for is does anyone have a recommendation for what is the best of these compressors to use. Or if someone knows where I might be able to source a new AC Delco part I would really appreciate them letting me know. I'm not looking forward to this job but it's already 110 here in Phoenix so I gotta get er done. Thanks
Old Jun 26, 2025 | 01:07 AM
Eleven Bravo's Avatar
Eleven Bravo
I used a NAPA remanufactured OEM compressor. I didn't want to spend the money on a new OEM piece, if I could find one. Mounted up to my brackets and hoses perfectly, and came with a good warranty.
Old Jun 26, 2025 | 09:21 AM
pjdbm's Avatar
pjdbm
If you can't source a NOS unit or can't wait to find one, then consider a NEW Fourseasons unit on/at Rockauto
This was the route I took.
Old Jun 26, 2025 | 09:37 AM
lucky131969's Avatar
lucky131969
https://www.corvetteforum.com/forums...ompressor.html
Old Jun 26, 2025 | 12:22 PM
JHrinsin's Avatar
JHrinsin
That's what I did.
Old Jun 26, 2025 | 03:12 PM
jfigus's Avatar
jfigus
I did the four seasons from rockauto too, no problems. It's been almost 4 years now. If your current compressor is totally shot, it could have contaminated the system. Contamination can lead to an early death of whatever replacement compressor you choose. You'll want to change the orifice tube and accumulator too. Given the age of these cars, you might want to replace the condenser while the system is depressurized.
Old Jun 26, 2025 | 09:40 PM
bookyoh's Avatar
bookyoh
This supplier shows one OEM compressor, accumulator, orifice tube package in stock. The build date code of the compressor is probably 2003 or 2004 if it is left over OEM.
After completing the oil balance with the OEM compressor, be sure to turn it over by hand for a bit because its been sitting on a shelf for 20+ years.
Old Jun 26, 2025 | 09:50 PM
Hotrodzz3's Avatar
Hotrodzz3
Who's the supplier?
Old Jun 26, 2025 | 11:24 PM
Hotrodzz3's Avatar
Hotrodzz3
Thanks for the recommendation my compressor is still working but I don't think it will be for long still blowing cold air. I figured since it's only a hundred bucks extra for everything and since it's such a pain to do this job I might as well change everything at once. Good to hear yours has lasted 4 years.
Old Jun 27, 2025 | 07:33 AM
bookyoh's Avatar
bookyoh
Originally Posted by Hotrodzz3
Who's the supplier?
SMCAUTOPARTS.com
Sorry, forgot to paste the link:
https://www.smcautoparts.com/AC-Comp...58a-aax017.htm
Old Jun 27, 2025 | 04:35 PM
Midwest19942000's Avatar
Midwest19942000
Based on what you’ve described it sounds like one or more of the seals on your compressor have failed and not necessarily the compressor itself which I leaned is a very common problem on the C5. My car was low mileage (25k miles) when this happed so I believed the compressor itself had a lot more life left. If you have a lot of mileage and use on your compressor then it may be worth replacing rather than rebuilding with new seals.
Otherwise, if you have time and are feeling adventurous you can disassemble and reassemble your compressor with new seals, and save a lot of money. Did this on my 2000. Linked below is a thread where I posted the info for the seal and o ring kits.
https://www.corvetteforum.com/forums...t-optimal.html
Old Jun 28, 2025 | 02:19 AM
Hotrodzz3's Avatar
Hotrodzz3
Thanks for posting this it will help me a lot I wasn't sure which way to take it apart I've seen 3 videos on how to do it and all 3 were totally different
Old Jun 28, 2025 | 02:39 PM
bookyoh's Avatar
bookyoh
If you found a puddle of compressor oil under your car, then you have a gross leak. I assume your a/c no longer works because the oil typically is carried out of the compressor by leaking refrigerant. There are multiple possible leak paths. So, if you plan to rebuild your compressor, it will be helpful to know where the leak is before beginning.
Specialized tools needed to:
Remove and install the clutch
Remove and install the pulley
Protect the lip seal on reassembly
If the compressor body oring joints are the leak, corrosion working its way under the oring is a common cause for leak. You will need to carefully remove the corrosion and smooth the sealing surface.
Old Jun 28, 2025 | 04:11 PM
Hotrodzz3's Avatar
Hotrodzz3
It's definitely a gross leak just started last week, funny thing is it still works well. I've decided to stop driving the car until I get this fixed no sense in filling the system with crap. For now I'm going to buy a replacement compressor and will keep the old one to rebuild later so I then have a spare.
To Replacing A/C Compressor
