Electrical Relay Experts
Old Aug 5, 2025 | 04:57 PM
AJ Powers's Avatar
AJ Powers
Default Electrical Relay Experts
The relay on the left was in position 44 of fuse/relay block (cooling fan 3).
The diagrams match and both are 40 amp. PIN layout matches. The form factor of the new one is obviously significantly smaller.
Is the new, smaller one compatible?
Thank you
Old Aug 5, 2025 | 07:37 PM
lucky131969's Avatar
lucky131969
Thank you
What leads you to believe the smaller relay is rated for 40 amps? The one on the right is an copy of the original Omron 7866....let me guess, Amazon? Made in the USA? I'm dubious.
You won't find the Omron 7234 anymore(unless you find NOS). The available GM replacement for that relay is GM 13503103.
Old Aug 5, 2025 | 08:28 PM
AJ Powers's Avatar
AJ Powers
You caught me. Yes, Amazon . Online specs say 40 amps. Thanks for the reference.
Old Aug 11, 2025 | 09:51 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Omron does make a relay with that Part Number, but it says Omron on it. So the one you got is probably a counterfeit (copy) relay.
Old Aug 11, 2025 | 10:27 PM
lucky131969
Discontinued years ago by Omron.
Old Aug 12, 2025 | 05:14 PM
PlanoLeMans's Avatar
PlanoLeMans
If the pin out is an exact match, it should work; after all it is just a simple relay. As to how long it will work is questionable. The quality of the smaller relay is unknown.
Old Aug 12, 2025 | 06:40 PM
lucky131969
To Electrical Relay Experts
