Bought a C5 recently look at all these codes
Old Aug 9, 2025 | 04:15 PM
Mrc522324's Avatar
Mrc522324
Default Bought a C5 recently look at all these codes
Engine & Emissions
  • P0143 HC
  • P0135 C
  • P0141 HC
  • P0154 HC
  • P0161 HC
  • P0300 H
  • P0463 H
  • P1125 H
  • P1258 H
  • P1280 H
  • P1281 H
Communication & Module
  • U1301 H
  • U1016 H
  • U1064 H (listed twice)
  • U1096 H
  • U1160 H
  • U1255 H
Body & Chassis
  • B0361 H
  • B0367 H
  • B2262 H
  • B2264 H
  • B2282 H
  • B2283 H
  • B2284 H
  • B2287 H
Chassis/Brake/ABS
  • C1226 H
  • C1278 H
  • C1283 H
  • C1293 H
  • C1294 H
Fuel/Transmission Control
  • C2100 H C
  • C2105 H C
  • C2110 H C
  • C2115 H C
Old Aug 9, 2025 | 05:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Most of these are “H” or history DTC’s….just erase all the codes and see what comes back the next few times you drive the car…most power plant DTC’s are “2 trip” DTC’s so the fault must be happening twice in a row for the DTC to set and the MIL to illuminate…as a new member it is best if you fill out your profile…as a minimum we need to know your model year.
Old Aug 9, 2025 | 06:59 PM
Mrc522324's Avatar
Mrc522324
thank you just did it’s a 02 c5
Old Aug 9, 2025 | 07:02 PM
C5 Diag's Avatar
C5 Diag
Great !!…thanks !!
Old Aug 10, 2025 | 01:30 AM
Mrc522324's Avatar
Mrc522324
Default Thanks
alright so I did what you said and these came back , the old owner said it’s got no cats , and a power steering leak but it went into reduced engine mode , ima have a mechanic check it soon but wanted to see if anyone has had this issue , it’s got 164,000 miles
Bo361 H
Bo441H
Po134
Po154
Old Aug 10, 2025 | 08:34 AM
C5 Diag's Avatar
C5 Diag
Well you and thousands of owners have had these issues…0134/0154 are O2 sensor codes and have nothing to do with no cats…the Reduced Power could be a number of things and you can have him look at the 2 other HVAC ones…hope your mechanic isn’t just a “parts changer” as the majority are…good luck !!
To Bought a C5 recently look at all these codes
