Limp Mode after puddle
Old Aug 14, 2025 | 01:05 PM
jarladin's Avatar
jarladin
1st Gear
Default Limp Mode after puddle
Hey all. First post here (unfortunately under bad circumstances). Got limp mode after rain. Went through a big puddle last night and went into limp mode with traction control light on Car shut off but turned back on after when cranking. Throwing P2135. I let it dry overnight but code still came back after i hit 40mph. I’m gonna try electrical contact cleaner on the throttle body connector. Any other things I should try before taking it to the shop next wednesday?
Old Aug 14, 2025 | 02:01 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As a new member it is ALWAYS a good idea to tell us the model year as a minimum when asking for help…can be a bad TPS sensor or wiring issue…if you don’t have either a DMM or a scan tool to be able to look at the 2 TPS sensor potentiometers let your shop diagnose it…best to check with a scan tool or labscope…there is a disagreement between the 2 sensors…most likely your shop will just replace parts.
Old Aug 14, 2025 | 06:04 PM
MrNiceGuy!'s Avatar
MrNiceGuy!
There is a YouTube channel called VetomVettes757 that has a series of videos on a very similar incident with his C5 Z06. He ram through some deep water and explains what he did to get his C5 back up and running. The first video in a series of 3 videos is labeled 4,372 views · 10 months ago...more
VetOnVettes757
[size=13px]IT FINALLY HAPPENED.. I OFFICIALLY BROKE THE Z06 THE DUMBEST WAY POSSIBLE. WE CAN FIX IT THOUGH[/size]
Old Aug 14, 2025 | 06:14 PM
lucky131969's Avatar
lucky131969
Big puddle? Exactly how high was the water?
To Limp Mode after puddle
